Urgent... please help!!!
Old Oct 15, 2004 | 03:02 PM
krasavchic's Avatar
What is the size of the original Bose speakers in '00 Maxima?
As I understand, the front ones are 6 3/4", and the rear ones are 5 1/4".
Is that correct?
What is the power of front and rear amps?
What is the power of the spekers?
Thank you very much
Old Oct 15, 2004 | 08:29 PM
Guinader's Avatar
sorry can't help you, but hey, free bump. maybe more people will see it.
Old Oct 15, 2004 | 11:49 PM
krasavchic's Avatar
Thanks anyway
Old Oct 16, 2004 | 06:07 AM
MannyNJ2k2max's Avatar
you can put 6.5"-6 3/4" front and back by simply placing a 1/2-3/4" mdf ring between the speakers and mounting location- you can also purchase these pre made and companies like Metra/Scosche make plastig mounts- there IS ENOUGH clearance between door panel an speaker- Do not limit yourself to the 5 1/4"
Old Oct 16, 2004 | 06:10 AM
Example.....
Old Oct 16, 2004 | 06:12 AM
filtor1's Avatar
I am using 6.75" all the way around. The rear panel has an odd shapr however and either needs to be cut or you can use the stock speaker and cut it out of it's housing and use the "mounting ring" that is left. This is a very easy way to save money and utilize a slightly larger driver in the rear. This will also eliminate any fitment issues as far as depth.
Old Oct 16, 2004 | 06:13 AM
filtor1's Avatar
P.S. Manny, excelent choice of components. I wish I knew of those before I bought mine.
Old Oct 16, 2004 | 06:46 AM
thanks, with so many choices in the field and limited dealers, its impossible to get a taste of everything when making a final decision- the fact that they were made by Rainbow , I knew I would be very happy with the results
Old Oct 16, 2004 | 11:42 AM
krasavchic's Avatar
Thank you, guys!!!
Manny, nice setup!!!
PoePoe2797
Oct 18, 2004 12:32 PM
