Need help!!!!!!!!!!!!!!!!
Old Oct 17, 2004 | 06:09 PM
9maxima5's Avatar
hey guys I need your help. I was thinking on runnin a neon light to my subbox and i decided to use the power source from the light in the trunk. I took it out and cut the two wires but now none of the light in the car will work. I mean the dome lights and the overhead lights. Anyone have any clue on fixing this?
Old Oct 17, 2004 | 06:14 PM
2 Da Max's Avatar
check your fuses
Old Oct 17, 2004 | 07:16 PM
craig10114's Avatar
u popped a fuse. check it and ur good, u probly crossed the wires when u cut them or they touched at one point
Old Oct 17, 2004 | 07:58 PM
9maxima5's Avatar
Thanks guy you are correct. But i still want to hook up the neon to the wires and every time i do it the fuse goes. How do i fix this like can i use a higher fuse
Old Oct 17, 2004 | 08:34 PM
2 Da Max's Avatar
are you making it so the neon comes on when the trunk opens? i would just run a switch to it since your keep blowing fuses
Old Oct 17, 2004 | 08:49 PM
friendhasmax's Avatar
you either shorted a wire, or the light is drawing too much power which i doubt is the case.
Old Oct 18, 2004 | 06:52 AM
craig10114's Avatar
if thats giving u problems then either run a wire from the cig lighter to the trunk and put a ground out switch on it to turn on when the trunk opens, or make sure u arnt reversing any polarity with that light
