Best Place to Ground.
Old Oct 25, 2004 | 06:46 AM
SKYRockerr's Avatar
I want to know whats the best Place to ground amplifiers in the Trunk? I have a 4 gauge power wire coming in, do i need a distrubution block 4gauge and 2 8 gauge ground wires in my trunk to properly ground it?
I am getting whine from the speakres , i am positive its a bad ground some where.
And whats a good place for radio deck ground, its grounded in the dash consule and i am sure that could also be a bad ground.
Thanks.
And the capacitor needs to be grounded, but should i ground the amplifier to the capacitor negative?
I hope i didnt confuse ya all
Old Oct 25, 2004 | 06:50 AM
mendon99's Avatar
tastey wheat
doesnt really matter just find a bolt connected to the chassis
Old Oct 25, 2004 | 06:54 AM
MaXaZoR's Avatar
Usually when I chosing a ground spot in the trunk I make a my own by using a self-tapping screw w/ a washer. First I will prep the area with rubbing alcohol then use a grinder to get down to the metal. Then just use a powerscrew driver and your done.
The radio in the front is a different story. I never use the stock ground because it was designated for the stock radio and not a powerful after market one. The best choice is to run a ground from the stock radio straight to the ground on your battery. Some people don't feel comfortable drilling a hole through their firewall so another option would be under the shifter there are four screws that hold in your shifter I will sometimes use one of those, make sure you clean the area with rubbing alchohol before hand.
Hope this helps
Old Oct 25, 2004 | 06:57 AM
mendon99's Avatar
tastey wheat
or any big piece of metal*
Old Oct 25, 2004 | 09:30 AM
Pearl96Max's Avatar
I tend to get a bit irritable
The "stock ground" is non existant for the HU. Meaning there isnt wire present in the harness at all. The factory radio uses a floating ground through the chassis.
SKYRockerr...Directly below the radio theres a bracket with a 10mm bolt on each side. Either will work fine for a ground.
--Don
Old Oct 25, 2004 | 10:05 AM
MaXaZoR's Avatar
Pearl96, this is true that 95 and up do not have factory grounds on the wire harness, but for previous year models like a 90 I believe did offer factory grounds.
Old Oct 25, 2004 | 11:36 AM
NismoMax80's Avatar
SuPeRmOd
for whine, make sure your power and audio/rca cables do not run near each other. Main power should go directly to battery. For a better ground, just try to find bare metal, best if using an existing bolt. Or scratch off paint where ground touches.
since when do capacitors get grounded? I had power run to cap and cap to amp.
Old Oct 25, 2004 | 01:29 PM
SKYRockerr's Avatar
My Rockford Fosgate Digital Cap, has a positive in coming on a 8 gauge split from 4 gauge , then the negative is grounded to the car.
Old Oct 25, 2004 | 03:17 PM
NismoMax80's Avatar
SuPeRmOd
you're right, I was trying to picture in my mind the wiring I did 5 years ago. the car and booming system belong to my sister now. I ran i think 8 awg to a distributor block. then (2 wires out) 8 to the cap and 8 to the amp. I grounded both the amp and cap with 8awg to a bolt above wheel well. (scratched off the paint for a good ground.
aw11power
Oct 10, 2021 04:57 AM
TKHanson
Nov 24, 2018 01:39 AM
Derrick2k2SE
Nov 19, 2015 10:14 PM
Junebug1701
Sep 25, 2015 01:54 PM
