Remote Turn on Wire with 2 amps...
Old Oct 28, 2004 | 01:48 PM
suprropmp's Avatar
I have an amp right now powering my subs. I want to add a second amplifier for speakers. My question is can i just jam the second remote turn on wire with the one from the first amp? Will the head unit be able to handle that?
Old Oct 28, 2004 | 03:13 PM
NISMO808's Avatar
You'll be fine.
Old Oct 28, 2004 | 03:40 PM
GodsmackMAX's Avatar
You will most likely be fine like nismo said, but if you add more components such as a cap or other accessories (neons, etc.) It is recommended to use a relay to switch 12v to the remote leads on everything.
drew
Old Oct 29, 2004 | 03:32 AM
Lystat2k2se
Ya it will be fine, i have done it many times
Old Nov 1, 2004 | 08:00 AM
KCMaxima98's Avatar
Ive got two amps running on a split REM wire from the head unit and it works fine. Some people suggest putting a .5amp fuse on the REM wire to protect the head unit but I didn't and haven't had any problems.
Old Nov 1, 2004 | 08:23 AM
myktek's Avatar
i use to have 2 amps, i just splice my remote wire...
Old Nov 1, 2004 | 09:47 AM
DJ Kontakt's Avatar
thats the way to do it. Just daisy chain the amps with the remote wire.
Old Nov 3, 2004 | 12:36 PM
yogi's Avatar
yep if it's only two amps that's going to work fine.....for 3 u need a relay
LtLeary
Sep 14, 2015 12:33 PM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
