ok my headunit is pissing me off (Pioneer DVH-5000P)
Old Nov 3, 2004 | 12:31 PM
Sprint's Avatar
1) When you put in a CD it doesn't play unless you hit SRC go to tuner and then back to DVD..
2) If you go to Tuner the CD is still playing, so when you go back to DVD/CD it isn't where you left it.
I will post when i can remember more...
please tell me i am not the only one who this pisses off..
Old Nov 3, 2004 | 12:45 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Never seen that one before Doug.....Your just special
Old Nov 3, 2004 | 01:00 PM
djfrestyl's Avatar
Suspension Yoda
arent there two outputs with the 5000? when u switch sources away from cd, is it still playing to the rear output? doug..make sure the rear output option is off using the 'rear' button on the remote.
don...does that sound right?
Old Nov 3, 2004 | 01:21 PM
Sprint's Avatar
yeah rear is always on
Old Nov 4, 2004 | 11:36 AM
djfrestyl's Avatar
Suspension Yoda
turn it off and see what happens? i only use my front output so it bothers me when im listening to the radio and want to listen to a cd, i put it in and the rear icon lights up. i have to turn it off and then hit source to get the cd to come through the front.
Old Nov 4, 2004 | 12:13 PM
Sprint's Avatar
no no.. you got it confused..
what happens is.. when i play a cd lets say track 1 ... i switch to radio.. when i come back to cd .. the cd is at like track 5. The cd doesn't stop playing
Old Nov 4, 2004 | 01:08 PM
djfrestyl's Avatar
Suspension Yoda
ahhh...that is weird!
sorry i couldnt be of more assistance - good luck!
Old Nov 4, 2004 | 05:25 PM
Sprint's Avatar
I know i am not the only one on this forum with this head unit
Old Nov 4, 2004 | 06:28 PM
GodsmackMAX's Avatar
Yes you are, because nobody is as rich as you are...
Old Nov 7, 2004 | 03:00 PM
Sprint's Avatar
someoneeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Old Nov 7, 2004 | 03:20 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
Yuo can select the mode between automatic playback and manual playback when you insert a disc into the disc loading slot. When the function is on, the disc will be automaticlly played after it is inserted a disc into the disc loading slot. Initially, this function is set to on.
1) press F repeatedly until AUTO PLAY appears in the display.
Old Nov 7, 2004 | 03:24 PM
killcrap's Avatar
Notes-
-If the CD playback is on, REAR will be displayed on the OEL display
-If you set AUTO PLAY : OFF, REAR will be displayed on the OEL display reguardless of wheather the rear display is connected to this product or not.
Old Nov 7, 2004 | 05:58 PM
Sprint's Avatar
Thank you Sir.. i was about to go crazy
worldwiderecognized
Sep 30, 2015 01:16 PM
jaydot901
Sep 29, 2015 01:18 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
