Sound Deadening
Old Nov 7, 2004 | 06:03 AM
Sp00ks01SE5spd's Avatar
Sound Deadening
I am sure this has been covered a few times and I"m also sure Dynomat is probably the best product to achive this. If your doing the entire car using Dynomat gets really expensive. Are there any reasonable alternatives to Dynomat that fits the wallet a little better? I've seen references to "B-Quiet" and "R-Blox". Has anyone used either of these products or do you have any other suggestions?
Yes I have the rear deck rattle......It's not too bad inside the car, I can hear it occasionally but outside the car is is really bad.
Old Nov 7, 2004 | 06:11 AM
GodsmackMAX's Avatar
eDead v3.0 :
Using it right now with a combo of v1.0!
www.edesignaudio.com
drew
Old Nov 7, 2004 | 07:45 AM
Ammi's Avatar
350 Detroit Muscle
Just get some Dynamat for the rear deck. It shouldn't cost much
Old Nov 7, 2004 | 07:58 AM
ZIPPIN's Avatar
Mauja He Mauja
how about peel and seel from home depot??
Old Nov 12, 2004 | 08:57 AM
PaulyPoTz's Avatar
jus get dynmat 50 bux will cover ur lid and may be ull need another 25$ kit for ur deck and u will have some left over... dynamat is the best out there i got 2 12" 1200w witta 1500w amp so that **** pumps...i had it installed and wen it hit those lows everythign shooke and it sounded stupid outside...added sum dynomat and most of the rattle dissapeared and u hear all bass...excelent product
Old Nov 12, 2004 | 09:52 PM
DJ Kontakt's Avatar
dynamat is overpriced , go for the edead or second skin audio product.
Old Nov 12, 2004 | 09:54 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Look intpo Second Skin. Ant is really great to work with and will help you out. Primary reason I became one of his dealers.
--Don
Old Nov 12, 2004 | 09:57 PM
Pearl96Max's Avatar
Any Factual evidence to back this up? What others have you had eperience with? Used? Compared to? Your opinion is fine and always welcome, but please post facts as this is a public forum that people read....
--Don
Old Nov 12, 2004 | 10:24 PM
Conrad283's Avatar
I need a truck
Dynamat is probably not the best out there. Simply the most known.
Old Nov 13, 2004 | 05:31 PM
AnDyMaN's Avatar
i used scoche mat from ebay. but since i live like 30 minutes away from a mobile dealer, i got it for 20 flat without shipping. i got 5 or 6 sheets of 12"x12" and it works great. all the rear deck rattle is gone and it sounds good. much better than getting dynamat for about 60 or so. its the sticky type so all you need to do it peel it off and stick it on the deck.
Old Nov 15, 2004 | 08:29 PM
03SE2HEAR's Avatar
Dynamat is by far the most well known...and good stuff too. I've recently tried this product called "Dead Skin" from www.Install Edge.com. So far only had time to do one door panel, but I'm amazed. This stuff is dense, is easy to mold, has a good foil backing and sticks like you wouldn't believe......just my 2 cents worth.
Old Nov 18, 2004 | 10:16 AM
machinehead's Avatar
--Don
i second this.
Old Nov 18, 2004 | 11:55 PM
mAxBaSs27's Avatar
I got 150+ sq ft of second skin in my car and i absolutely love it. Ant is a great guy to work with. check out his website www.secondskinaudio.com . its alot cheaper than Dynamat and i feel it is as good of if not a better product than Dynamat.
Old Nov 19, 2004 | 08:25 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
raammatt rules...you'd be hard-pressed to find anyone on elitecaraudio.com to disagree
Old Nov 19, 2004 | 08:53 AM
Wil's95SE's Avatar
我爱台湾
I'm not going to say that Dynamat is the best but i will say that I applied Duna Extreme to my trunk and rear deck plus I also used FatMAT on top of DE and It has made a hell of a difference with sound deadening in my car. My trunk would rattle so much that it broke the leds in my spoiler, thus I removed it and haven't replaced it yet. But after sound proofing the car it does not rattle anymore.
Old Nov 21, 2004 | 02:59 AM
krasavchic's Avatar
Guys, how much of eDead V1.0 is needed for rear deck?
Mahmuth
Aug 16, 2024 08:23 PM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
