Problems w/ my setup help..
Old Nov 7, 2004 | 11:30 AM
blackmax01's Avatar
Ok, i have the stock system bose headunit etc. I also have a Alpine type-r 10 in the trunk with a 480watt sony explode amp hooked up to the existing system. I have this little switch witch can turn the bass on and off. The sony amp is hooked up for the 10 and its all wired good with good wiring. Only problem is after about 5-10minutes of bass with my sub turned on the sub cuts in and out. I cant figure out what the problem is someone help please?!?!
Old Nov 7, 2004 | 12:12 PM
generation3's Avatar
Do you have a safety feature that turns off your amp when it gets too hot? It could be overheating.
Old Nov 7, 2004 | 01:04 PM
suprropmp's Avatar
thats most likely whats happening.. next time it happens try powering off your head unit (and thus powering off the amp) for a few minutes, that should take care of it
Old Nov 7, 2004 | 05:12 PM
blackmax01's Avatar
yea thats what im thinking...but a 480 watt amp shouldnt be overheating from one 10 afer 5min u kno??
Old Nov 7, 2004 | 09:58 PM
Pearl96Max's Avatar
I tend to get a bit irritable
What impedance is the sub running at? Most likely your problem. Also if the amp is mounted without sufficent ventilation in higher climate areas it could very well overheat in a short amount of time....
--Don
Old Nov 8, 2004 | 07:34 AM
blackmax01's Avatar
i currently moved the sub from under the passenger seat to where it was getting No air and prob over heating im guessing. I mounted it to the top of my box so it shuld be getting plenty of ventilation. Where is a good spot for my ground? It shouldn't overheat in the trunk now im hoping.
Old Nov 8, 2004 | 07:35 AM
blackmax01's Avatar
--Don
quick question....what is an 'impedance" dont kno much about car audio...
Old Nov 8, 2004 | 11:35 AM
isac's Avatar
what Pearl96Max is asking you is wether your sub is 4 or 8 ohms, or if it is a dual voice coil sub. I'm not sure what amp you have, but if it is a 2-channel amp, most likely the best way to run it is bridged, with a four ohm impedance, if your impedance is lower (ex. 2 ohms) your amp will overheat.
Old Nov 8, 2004 | 12:01 PM
Drippin's Avatar
Your amp may be overheating. Is it in a tight confine?
Old Nov 8, 2004 | 06:27 PM
blackmax01's Avatar
i just decided im going to go to best buy and update my whole system, sick of it being ghetto, im gonna go all out. I will post pix soon...
Old Nov 8, 2004 | 06:53 PM
AscendantMax's Avatar
going "all out" and Best Buy doesn't really go hand in hand
Old Nov 8, 2004 | 09:42 PM
Pearl96Max's Avatar
You So definately beat me to that!
knight_yyz
Nov 6, 2015 02:34 PM
knight_yyz
Oct 24, 2015 08:05 AM
