removing rear deck
Old Nov 7, 2004 | 01:10 PM
ckymaxx's Avatar
removing rear deck
hi, I was wondering if any knew how to remove the flimsy rear deck along with the bose speaker covers and third brake light. I want just bare metal in the back.
Old Nov 7, 2004 | 01:52 PM
Conrad283's Avatar
I need a truck
What year car do you have?
Old Nov 8, 2004 | 07:04 AM
ckymaxx's Avatar
it's a 1999
Old Nov 8, 2004 | 08:16 AM
Wil's95SE's Avatar
我爱台湾
If it's the same as a 95 all you have to do is remove the back seats. Once that is done, you will see 2 bolts that hold the front part of the rear deck down. Unscrew those bolts, lift up a little and slide the rear deck forward. Should come out with ease. I removed mine a couple of months ago and used fatamat liquid as a sound bearer because my subs hit so hard they loosened the speaker grill covers and they rattled everytime my bass would hit.
Old Nov 8, 2004 | 12:11 PM
Drippin's Avatar
Most rear decks us snap in clips to hold the panel to the metal structure. From underneath, you may be able to squeeze the clips and push up on them. Once they're all out, the panel may be removed.
Old Nov 8, 2004 | 02:13 PM
A32Matt's Avatar
what about the 3rd brake light though? i've been wondering how that comes out even though i don't have one.
Old Nov 12, 2004 | 06:54 PM
turbosupra18's Avatar
I have the same question... once you get the two lower screws holding the back of the rearseat off, does the seat just come off?? or is there more to getting to the rear deck??? i need help asap. thanks.
Old Nov 12, 2004 | 06:57 PM
Black Maxima
It hooks on too. After you take those screws out, lift up the seat.
Old Nov 15, 2004 | 07:48 AM
Shadow's Avatar
It's just clipped in there, plastic clips. I removed mine a while back and redid the rear deck to cover the hole.
Old Nov 15, 2004 | 05:56 PM
ghettomaximaz's Avatar
http://www.carstereohelp.com/stereor...Max96RSpkR.htm
This will show you how to do it but w/o the rear deck light, i too am unsure of how to get the deck off with the light there, any help?
Old Nov 15, 2004 | 06:09 PM
AscendantMax's Avatar
well on my 3rd gen, the light is held in by these plastic clip thingies. u pop these circle covers on each side of the housing and then remove the plastic clip. unhook the wiring harness and it comes out.
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
doctorpullit
Sep 10, 2015 06:33 PM
