Stock Bose system *PROBLEM*
Old Nov 12, 2004 | 06:31 PM
spiromax's Avatar
Seoul Man
I drive a 2003 SE with the stock Bose system and six disc changer. Recently, I noticed that all of my music seems to be missing something. I just figured out what it is today. My front left speaker sounds really crappy.
I tuned to a local FM station and tried using Balance and Fade to test all of my speakers. Front right, rear right, and rear left are all fine, but front left sounds dirty, as if the radio station was full of static.
It gets even worse when I switch to CD. Once again, the other corners sound fine, but instead of just souding dirty, the front left gives me almost NO music. It only gives me very light static, and when I turn the volume WAY up, I hear faint music from the front left.
If the speaker is blown or somehow damaged, I'm not sure why it would give me better performance on FM than on CD. This leads me to believe that the problem is elsewhere in the system. I'm more into performance than car audio, so I don't know my way around a car audio system. Any input you guys have would be really appreciated.
Old Nov 12, 2004 | 07:05 PM
HustleLikeM0FO's Avatar
2003 should have warrenty that should cover the audio system. take it to a Nissan dealer
Old Nov 12, 2004 | 07:14 PM
spiromax's Avatar
Seoul Man
Drivetrain warranty is 60k, but I'm pretty sure my bumper-to-bumper (which would include audio) is expired. Isn't the total warranty only 36k?
Old Nov 13, 2004 | 04:46 AM
Audtatious's Avatar
Bandwagon Lover
Unless you have less than 36k on the car, you are SOL.
Try smacking it to see if the static goes away. Mine did it for a while and after hitting it a couple times it has been doing OK.
Old Nov 13, 2004 | 09:14 AM
spiromax's Avatar
Seoul Man
So... either get it done under warranty... or smack it?
I heard that this is a common problem with the Bose system, at least on the 5th gen. Nobody has solved it?
Old Nov 13, 2004 | 12:27 PM
LithiuMax
I just had the same thing happen to me.. I've been told to get the headunit replaced under warranty. I think I may just take the entire Bose crap out of my car and put in all new aftermarket equipment.
Old Nov 13, 2004 | 12:44 PM
Loe max's Avatar
If your out of warranty, you'll have a heart attack when they give you a price quote on a new HU
Old Nov 13, 2004 | 09:40 PM
spiromax's Avatar
Seoul Man
Thanks for all the input, guys! I think sucks that the search feature is disabled on the org, but I went and sifted through some old posts until I found an answer that may even help those of us who are out of warranty. This left-side speaker failure is a known issue to Nissan, and there was a TSB issued for 5th gen Maximas with the Bose system.
Read the TSB here: http://www.infinitihelp.com/Ownershi.../NTB03-017.htm
Old Nov 14, 2004 | 11:40 AM
roofadoofalus's Avatar
i do not suggest smacking your speakers
Old Nov 14, 2004 | 12:04 PM
Max Mutes's Avatar
Sorry, not to take the thread off topic, but damn that Civic is BAD. You should take your sig and show it in the Sig Thread. I'd post the link for you, but I forget where it is exactly.
Old Nov 14, 2004 | 08:37 PM
it isnt too ricey in my opinion. are those rims racing harts?
MikesChevelle
Nov 23, 2024 11:17 AM
6spd4dsc
May 9, 2022 12:30 PM
melteye
May 16, 2016 12:02 AM
homeyclaus
Sep 3, 2015 06:15 PM
Maxinesdaddy
Aug 21, 2015 11:43 PM
