Antenna Wont Go Up
Antenna Wont Go Up After New Head Unit Install
Just installed a new deck and now my antenna wont go up. (no bad jokes please) I 1st thought it maybe a loose crimp connection so I took it all back apart last nite and soldered all the wires instead of using crimps. Now I have eliminated the possibility of a bad connection. I also checked all the fuses inside the car. Are there any other fuses that are connected to the antenna circuit? I am at a loss on this, anybody got any ideas? Thanks!
Deck = Pioneer DEH-P2600
Bump.........
Bump.........
Make sure the blue wires are hooked to each other. Usually their is like 1 blue with white stripe wire on the radio harness and a blue and blue with white stripe on the car harness I usually just hook up all three. This should fix the problem
You have to get some special wire. It's been so long since I did it so I don't remember the specifics, but if you tell a audio install place what's going on they should be able to give you what you need. I think it was about $10.
what are the colors of the wires before they enter the connector.. example.. black/red, blue/ green, blue /black strip.. etc...
-blake
there is no harnes just wire.. thats the prob.. i think that i may have found the wire.. the wire im lookin at now is a black wire with red stripe. i need the colors of the wires inside the factory electric tape.. if i can ill post a pic showing more of wht has been done
-blake
-blake
Violator
Sep 9, 2015 10:14 AM
98nismomax
Aug 13, 2015 12:44 PM
