Ohm Question
Old Nov 21, 2004 | 12:57 PM
Kikcaffine's Avatar
Ohm Question
How many ohms of resistence are made from 4 12's that are 2 ohms a piece, single voice coil?
Old Nov 21, 2004 | 02:22 PM
DR-Max's Avatar
Wiring the voice coils in parallel will give you 1 ohm, series will give you 4.
Old Nov 21, 2004 | 04:25 PM
Kikcaffine's Avatar
can most 1 ohm stable amps run 4 12's?
Old Nov 21, 2004 | 04:50 PM
DR-Max's Avatar
Reading your initial question again, my answer was based on subs with dual voicecoil (dual 2ohms). With the dvc, you get 1 ohm (per sub) wiring each voice coil in parallel, and 4 ohms (per sub) in series.
To quickly answer your question, (4) 12' subs that is 2 ohms each (single voice coil) will not work with one amp because it will give the amp less than an ohm of load. Most amps aren't stable in <1ohm of load. The only time you can use all 4 of your subs is if you run a separate amp on each one. Or use only 1 sub which will drive your amp into 2 ohm load.
Look at these links for further info:
http://www.jlaudio.com/tutorials/dvc/index.html
http://www.jlaudio.com/tutorials/wir...dex.html#3svcp
Hope this helps.
Old Nov 21, 2004 | 06:15 PM
Maxima Dan's Avatar
You can mix series and parallel to get a final 2 Ohm load from 4 2 Ohm subs. That's probably your best bet.
Old Nov 21, 2004 | 06:29 PM
Kikcaffine's Avatar
Will mixing the loads make it have different levels of sound output comming from each speaker? If i mix the resistances is it alright if i use 1 amp still?
Old Nov 21, 2004 | 09:42 PM
krasavchic's Avatar
Yeah, it's fine... as long as your amp is that powerfull to push all four of them. You can wire them as following:
Sub A & B in parallel = 1 ohm load
Sub C & D in parallel = 1 ohm load
Connect these 2 loads in series, so that you get 2 ohms
That's what people usually do with 2 DVC subs.
Old Nov 21, 2004 | 09:43 PM
krasavchic's Avatar
Just curiosity, what subs and amp are we talking about?
Old Nov 22, 2004 | 08:36 AM
Kikcaffine's Avatar
Polk Momo subs the mm1202 and either a polk c500.1 amp or a planet audio 1250.1 amp or a boston acoustics gt-28
Old Nov 22, 2004 | 08:47 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Hope this helps.
Actually I think your first post was right on with either a 1 or 4 Ohm. As well as MaximaDans with combining series/parallel.
The amp could also work if it was a 2 channel..2 Ohm stereo capable.
--Don
Old Nov 22, 2004 | 09:17 AM
DR-Max's Avatar
Hmmm....never thought of it that way! I never had that many subs to wire together and give the least amount of loads.
Kikcaffine, how are you going to fit (4) 12" in the trunk?
Old Nov 22, 2004 | 01:51 PM
Kikcaffine's Avatar
2 in the back, and one on each side the back 2 are in, the side two will prove to be difficult though
Old Nov 22, 2004 | 02:07 PM
DR-Max's Avatar
Interesting......all 4 subs are going to be inside the box firing outward, from its own chambers? If so, that's going to be a pretty big box...no?
Old Nov 26, 2004 | 07:28 PM
Kikcaffine's Avatar
i will effectevly have no trunk!
Old Nov 30, 2004 | 04:04 PM
DR-Max's Avatar
I found this link which should be very useful, it has many tools. Enjoy!
http://www.the12volt.com/caraudio/boxcalcs.asp
jmlee44
Oct 2, 2022 02:13 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
