Infinity Reference Tweets
Old Nov 22, 2004 | 09:29 AM
HondaKilLR's Avatar
good? bad? Worthwhile if not powered? Let me know what you think.......
Looking to replace stock Bose tweeters. Other options would be Rockford Fosgate Fanatic P's Q's X's.......
Old Nov 24, 2004 | 09:16 PM
Powerman5115's Avatar
I love Infinity, it's the only speakers I buy. I would go for the Kappa or Perfect tweeters, unless money is a problem, they are a little more expensive. I haven't heard anything about Rockford tweeters, nor have I heard their speakers so I can't say anything about them. If you can go and listen to them both, and decide what you like.
Mooney
Old Nov 24, 2004 | 09:54 PM
Park2670's Avatar
The Ultimate Driving Machine
yes im a huge fan of infinity myself also, im savin up to get perfects and kappas for my system
Old Nov 26, 2004 | 05:53 AM
Audtatious's Avatar
Bandwagon Lover
I have the Reference set in mine now. They are not too bad, but I definately miss my Quarts. Just about any aftermarket tweeter would be better than the factory.
Old Nov 26, 2004 | 06:00 AM
guyincognito's Avatar
I had the reference in for about 2 months but ended up blowing them. I now have a set of kappa perfect components and am powering them with an alpine amp. I highly recommend the kappa perfects.
Old Nov 26, 2004 | 10:09 AM
roofadoofalus's Avatar
which alpine amp are you using
Old Nov 26, 2004 | 12:46 PM
Epacy's Avatar
Unsuccesful STL Coordinator
I have the 6.5 Kappa Components. Only powered by the deck. Pioneer DEH-7200. The tweets are really bright. It is a nice sound.
Old Nov 26, 2004 | 08:04 PM
they would sound a whole lot better if you were to hook up an external amp to them
Old Nov 27, 2004 | 01:29 PM
I am using the MRV-F540
Old Nov 28, 2004 | 03:07 PM
joebangaa's Avatar
i think references are disgusting. those tweeters are beyond harsh
Old Nov 28, 2004 | 04:12 PM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
true, they are the lowest lvl that's why....kappa and the kappa perfects are much better.
Old Nov 28, 2004 | 09:25 PM
disgusting you say?
Old Nov 29, 2004 | 06:56 AM
joebangaa's Avatar
yes i said disgusting
in fact most tweeters i've heard are quite nasty. those references are really bad, in fact i don't like the kappas or perfects. correct me if i'm wrong but i think it's cuz of the low frequency cutoff for the mids causes too much signal to be sent through tweeters thus creating an even more higher pitched sound on top of the tinniness that already exists. mbquarts, don't like em either.
everyone's different, for me, i need smoth laid-back tweets, so i went cdt
Old Nov 29, 2004 | 07:53 AM
Big_Ham's Avatar
MaximaFreak
And mis-information flows.
Tweeters are subject to listening just like ALL car stereo gear. The only thing you can say objectively is how many dB's a system puts out, whether equipment is reliable, whether something is heavier than something else, etc. Everything else is subjective and up to the listener.
True about cutoffs is if the components are far apart (as they are in the Maxima) a lower tweeter cutoff will allow you to actively cross them over and create a larger overlap between the low end cutoff of the tweet and the high end cutoff on the woofer. This allows for a more seamless transition between the two and they won't seem as "separate" as they can sound with higher, identical cutoffs. Having tweets up high can benefit you greatly by raising your soundstage as well.
I auditioned on an A B C switch the Reference, Kappa and Beta in a listening room many years ago and I HATED the Kappas. Reference blew them away in my opinion. This is because I have highly attenuated hearing and the metal dome tweeters sounded very raw. This can be corrected with equalization, but even then I find soft dome tweeters to be warmer and more realistic. Needless to say, I found the Betas to be superior and I still run them in my car to this very day. They're some of the best sounding components I've heard ... and the tweeters are capable of going all the way down to 1500Hz. They can be had on eBay for under $200 for the set now, too.
CDT makes excellent components and have for years ... all the way back to when they were still Clif Designs. These are an excellent mid-high end choice, but to save money and buy Reference's would also be a good bet. You just cannot overpower them as they are not meant to scream at you or hold that kind of wattage. You can consider that a shortcoming if you want, but I have infinity reference coaxes (602II's) from approximately 1995 that saw action for many years that still work very well to this very day and sound great.
In car audio, it is no longer true that the more money you spend, the better equipment you get. Go listen to anything you are considering and make your decision based on that. Don't ask in a forum if it sounds good.
Old Nov 29, 2004 | 10:29 AM
joebangaa's Avatar
i ran a mere 75w to my references and blew the mids not to mention a xover went bad on me, not even from clippage
both of my coaxes went to dust too, you can just tell by the construction of these drivers they need to be carefully powered. the cdt's i got are soooo much beefier and love whatever power i give them. infinity's textile tweeters sound no diff from metal to me
Old Nov 29, 2004 | 10:46 AM
TheBigDu's Avatar
How are Alpine components??
Old Nov 29, 2004 | 02:11 PM
how much does a set of cdt 6.5 components cost
Old Nov 29, 2004 | 02:17 PM
joebangaa's Avatar
i got mine for 165 and i just found out the guy i got them from dropped the price to 150, the bastard! haha this isn't for the entry level one either
litch
123
Jan 4, 2024 07:01 PM
trsandrew
Apr 8, 2016 06:45 PM
RinconI30
Nov 10, 2015 10:55 PM
trsandrew
Oct 25, 2015 02:47 PM
James92SE
Oct 8, 2015 04:57 PM
