Sub options
Old Nov 23, 2004 | 09:09 PM
maxim240sx's Avatar
Sub options
I know you maxima guys are audio addicts,so I thought I'd ask you guys for advice. I have a 97 240sx,as you know it has very little trunk space. I really want a box that isn't too big right now, I don't wanna build a custom enclosure for awhile. And don't have alot of watts to give either. I have a PPI pcX5800 amp. It's 50x4 and 200x1 @4ohm,and 100x4 and 400x1 @2ohm. I had another question about the power output. Can I run the 4 channels at 4ohm and the sub channel at 2ohm? Or do I have to run all at 2ohm or 4ohm? I bought a virtual technologies 8" slot ported box for $10 from the local audio store.Dimensions are 24x11x10.5 port is 9"x25" long. I could enlarge the mounting hole to accomidate a 10" sub also. So I guess I'm looking for either a 8 or 10" sub to handle somewhere between 200-400 watts. I'm also open to a 12" sub and box if it isn't too large. Anyone have any good idea's?? thanks
Old Nov 24, 2004 | 05:24 AM
Robert_J's Avatar
Are those internal or external dimensions? If they are external, how thick is the wood? You are missing one measurement on your slot port. Shouldn't it be 9x?x25?
Budget? Elemental Designs just released a new 8" for around $50. It looks great when modeling it. There are many other options depending on how much you want to spend.
-Robert
Old Nov 24, 2004 | 09:46 AM
2 Da Max's Avatar
a 240 is a hatchback so a bazooka tube will sound good, just get one of those empty audiobahn bazooka bass tubes and throw a sub in there
Old Nov 24, 2004 | 10:46 AM
maxim240sx's Avatar
Sorry about the dimensions. Those are on the outside. The wood is 5/8th" and the port is 25x9x1.75". Price isn't all that important, but I don't want to spend $350 on a jl 8w7. Looking to spend between $100-200. Also 2da max, my 240 is a coupe with a trunk.
Old Nov 24, 2004 | 11:53 AM
Robert_J's Avatar
Based on the T/S specs, the 9Kv.2 looks really good. The $50 price tag looks even better.
-Robert
Old Nov 24, 2004 | 01:25 PM
Bmxracer813's Avatar
how bout a eclipse aluminum http://www.woofersetc.com/product.as...9&1=285&3=3354 good sub
Old Nov 24, 2004 | 01:46 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Good sub, but I definately would Not buy it from there....
--Don
Old Nov 24, 2004 | 02:01 PM
Conrad283's Avatar
I need a truck
Arc audio car series would be a nice touch. The amps are small and the subs don't require a lot of cubic volume. And not relatively expensive to boot.
I have em, so it's no BS.
Old Nov 24, 2004 | 04:46 PM
mendon99's Avatar
tastey wheat
that sub would be underpowered with that amp.. could take and would sound better with more wattage... id go for a JLW0 or maybe a W3
Old Nov 24, 2004 | 04:49 PM
roofadoofalus's Avatar
why wouldnt you buy from there
Old Nov 25, 2004 | 09:20 AM
maxim240sx's Avatar
that ED sub looks pretty beefy for an 8" sub. Great price too. Do you think I would be better off with a higher end 8" or a mid range 10" for the money and watts to give? thanks for all the input guys
Old Nov 25, 2004 | 09:51 AM
2 Da Max's Avatar
check out the sticky pearlmax made
Old Nov 25, 2004 | 09:52 AM
Pearl96Max's Avatar
Simply because you lose your three year warranty, and you dont know where its actually coming from.....
--Don
Old Nov 25, 2004 | 10:12 AM
Robert_J's Avatar
If you still budgeting up to $200, you don't have to settle for midrange anything. You just need to look beyond the "name brands". Here are some examples:
Soundsplinter RL-i 10" ~$150
Resonant Engineering RE series 8" $50, 10" $60 or SE 10" $150.
Peerless XLS $140
Dayton Titanic MKII $140
Dayton Titanic MKIII $140
ED 11Kv.2 $115
Everything above will work just fine with the 200-400 watts you have available. Some have different voice coils arrangements others are just single 4 ohm VC's.
-Robert
Old Nov 26, 2004 | 10:39 AM
slickrick's Avatar
yeah the 9kv2's are nice... get 2 of them with about 150 watts on each.
Old Nov 26, 2004 | 10:53 AM
YellowOne's Avatar
i'm in okc, and have a jl 10 in a factory jl 10 bandpass box that i would let go for $150, doesn't take much to push it either. i'm running it on an old kenwood amp that max would put out is 200w if i'm lucky. sound dam good for just one ten. if you're intrested pm me. i'll let you listen to it.
Old Nov 26, 2004 | 08:05 PM
thank you for the clarification
Old Nov 27, 2004 | 10:26 AM
maxim240sx's Avatar
I'm thinkin about tryin out those Ed subs for $50. Can't beat a deal like that. I appreciate all your ideas and input. thanks alot
Apr 16, 2020 05:15 AM
Mar 12, 2020 12:06 AM
Robert Schneeweis
Jan 11, 2017 06:47 PM
Redfox
Sep 28, 2015 10:41 AM
Vistance
Sep 17, 2015 05:17 AM
