System With Stock Radio
Old Dec 10, 2004 | 09:23 AM
bi30's Avatar
Sup,
Anyone knows how to hook up a system (sub and amplifer) to stock radio.
Any website on how to do?
Thanks.
Old Dec 10, 2004 | 09:43 AM
HomerMAC's Avatar
Donating i30 Owner
... ahh connect the highlevel line before the amp from the rear subwoofers.. unless you wan to do it from beind the headunit.. in which case you can buy a little adapter thingy that will turn ur headunit output into rca... so two choices.. and as for the aca out thing.. GOOGLE my friend.. GOOGLE....
Old Dec 10, 2004 | 11:48 AM
leeI35's Avatar
G37S > I35 > UR Max
Originally Posted by bi30
Sup,
Thanks.
This is a do it yourself install. It's pretty easy and this was my first time doing my own install. I don't have a diagram or instructions but it's pretty simple. You have to get behind the main radio and make sure you have a line converter and 12 gauge wiring kit. I got all stinger wiring, but you can get all types out there and better quality. I have Focal component speakers + a farad cap + stock bose amp + Jl Audio 500/1 + JL 10w7 all controlled by the stock radio, minus the base ****. Make sure you have a drill because the hardest part is drillina a hole from the cabin through the firewall to the engine bay for the wiring. After that, read instructions and everything should be fine. Get a friend and a six or 12 pack of whatever, that should be fun. Plan on losing about 3-5 hours of your time if you are not experienced like myself.
Old Dec 10, 2004 | 12:08 PM
thephatOne's Avatar
i hope you meant 2 instead 12 gauge...12 gauge
Old Dec 10, 2004 | 12:25 PM
leeI35's Avatar
G37S > I35 > UR Max
You are right here is the descriptions.
20 ft 2 AWG power wire (red), 10 ft 4 AWG power wire (red) and
10 ft 4 AWG power wire (black)
RCAs
Line Converter
Fuse Block
Battery Connector
Old Dec 10, 2004 | 02:14 PM
SuBXeRo's Avatar
it depends on what inputs u have, high level or RCA. either way if you tap off of ur rear speakers u need a line in converter. converts the conector to rca and cleans up the signal big time.
what system u gonna be running
Old Dec 10, 2004 | 02:51 PM
thephatOne's Avatar
your ground wire should be larger than your power wire
Old Dec 11, 2004 | 05:02 PM
i30ds's Avatar
Armed and Dangerous
I installed a 12'' MTX with amp to my stock Bose system. It was years ago so I don't remember the exact procedure, but it can be done. The main thing is to tap the right wires and get the adapter. I would not recommend it though as I could never the full quality sound out of the woofer.... it seemed distant.
Old Dec 12, 2004 | 02:20 PM
SuBXeRo's Avatar
i dunno about you but i have crystal clear sound from my subs, your enclosure has to be sealed and tuned right to the sub or it ewont be clear, also depends ont he settings of your amp, and well mtx good, so i dunno, but you def need that converter, it makes the world of difference, i mean a hell of alot.
9aj9
Apr 5, 2020 12:11 AM
BkGreen97
Apr 2, 2016 05:47 AM
220k+ A32
Sep 11, 2015 02:18 AM
Pnjboyzz
Sep 4, 2015 09:04 AM
TheMafia
Sep 4, 2015 08:26 AM
