Is this box too big for my subs?
Old Dec 22, 2004 | 01:00 PM
KCMaxima98's Avatar
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWA:IT
I have a pair of two old punch xlc tens that I am thinking about giving to a friend to provide some budget boom in his car. I think that the manufacturer suggests that these subs get .75 cubes each in a sealed box. I put the dimensions of this box into a calculator and came up with 1.25 cubic feet each (Not counting the divider in between and the space that the drivers will take up). Are my calculations correct? Is that too big? How will this affect SQ and power handling on these subs?
It looks like a good cheap box. I mean it is 3/4 mdf. What do you think?
Old Dec 22, 2004 | 04:20 PM
KCMaxima98's Avatar
Okay here are the specs on the subs if that will help you answer my question...
Rockford Fosgate Punch XLC RFP-2410
10" Subwoofer with 4-Layer, 2" Voice Coil, Aluminum Former, Dual Laminated Foam Surround, Spruce Pulp Paper Cone, Hyper-Extended Pole Piece, Aero Vent Base Plate, Magnet Bumper, Dual Laminated/Progressive Flat Spider, Nominal impedance 4 ohms and 8 ohms, RE (DC resistance in ohms) 3.7 and 7.3, RMS and Peak Power: 200 and 400 Watts, sensitivity: 87dB, FS (Hz) 30 and 32, QMS 5.38 and 5.23, QES 0.39 and 0.47, QTS 0.36 and 0.43, SD (cone area) 54.26in2, VAS (cubic ft) 1.62, XMAX (inches) 0.31, Voice Coil Diameter (inches) 2.0, Mounting Depth (inches) 4-1/2, Speaker Displacement (cubic ft) 0.06, Recommended Enclosure (cubic ft) Sealed=0.75 and Vented=1.0
Old Dec 23, 2004 | 08:03 AM
KCMaxima98's Avatar
bumpppppppp
Old Dec 23, 2004 | 08:30 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
the bigger the box, the less power you need to reach full excursion
Old Dec 23, 2004 | 10:03 AM
2 Da Max's Avatar
the bigger the box, the lower the power handling for the subs at higher volumes
Old Dec 23, 2004 | 10:05 AM
KCMaxima98's Avatar
So it would sound ok in this box?
And as far as power handling, will .2-.3 cubic feet make that much of a difference?
Old Dec 23, 2004 | 10:20 AM
2 Da Max's Avatar
na that box is good, its a regular dual 10 inch sealed box, its not like its ported or anything. not a bad price, id buy it
Old Dec 23, 2004 | 11:11 AM
KCMaxima98's Avatar
I thought about building it but I don't have enough material left from the last one and since this box on ebay is so cheap it almost isn't worth building one anyway.
Oh, almost forgot. What would be a good way to wire these in parallel in this box? Drill a small hole in the center divider to daisy chain the wire or what?
MaxiNoob98
Oct 2, 2015 10:13 PM
MichMaxFan
Sep 30, 2015 09:18 AM
Redfox
Sep 28, 2015 10:41 AM
Sep 27, 2015 08:37 AM
