DYNOMATT Please Help
Old Jan 3, 2005 | 08:54 AM
TheGAMEGUNIT05's Avatar
Dyno-Matt Trunk
Has anyone done this? does it get rid of all rattles?.. I tried stuffin the towel in the back deck, and I tried putting a towel where the rear deck light is to stop it from hitting the window, but I still hear rattles.. Wondering if dynomatting is the way to go, or will I be wasting my money..
Old Jan 3, 2005 | 09:17 AM
Automonjama's Avatar
I installed it in the trunk of my 2002 Altima because i had the Stillen exhaust and I was getting some droneing in the cabin of the vehicle. I also had the sound deading sprayed in at Ziebart and I could not tell any difference so i would have to say that it is a waste of money.
Old Jan 3, 2005 | 10:56 AM
1Hot6Gen's Avatar
Dynamat is a waste of money for the rear deck rattle.
what i did was i went to Home Depot and went into the air conditon insulation section and bought 2 packages of the foam that they have and then i stuffed the rear deck with it.
then i removed the rear brake light and they sell a skinny foam insulation tape. I wrapped it around the lite and pushed the lite back in
Old Jan 3, 2005 | 02:48 PM
msoemax's Avatar
Dyno-matt is some expensive stuff. It's overkill for what you are trying to do. I can second the air conditioner foam insulation; it works well. The harder part is to find a sticky double sided tape that's really sticky. I have had no luck finding really good tape. Regardless, I have used this in several problematic areas in the car. Works good and it's cheap. ~$5-$10
NewEngSurf
Feb 21, 2005 09:04 PM
NewEngSurf
Feb 21, 2005 02:31 PM
TheGAMEGUNIT05
Feb 17, 2005 07:31 AM
TheGAMEGUNIT05
Dec 16, 2004 07:50 AM
