amp heat question
Old Jan 3, 2005 | 03:58 PM
sachmo12345
amp heat question
if i were to have my amp under some towels would it overheat??? its an MTX 801d powering a MTX 9500 12"
Old Jan 3, 2005 | 04:37 PM
slickrick's Avatar
it would be worse. mount them veritcally and in a well ventilated place or go buy some small computer fans.
Old Jan 3, 2005 | 04:45 PM
sachmo12345
it doesnt over heat now just wondering if i hide it but i think i have a good idea of how to mount it
Old Jan 3, 2005 | 04:50 PM
slickrick's Avatar
well i guess it all depends on where you mount it for security purposes. but i would not put a towel over it.
Old Jan 3, 2005 | 05:26 PM
2 Da Max's Avatar
not to be nosey.. but why would you put towels over it?? you dont like the way it looks? lol
Old Jan 3, 2005 | 05:58 PM
sachmo12345
no no no not that at all you see
the trunk of my car (95 Max) was not level at all and i could get my sub to stay still so i packed below the trunk mat with towels and now it is nice a level and i want the amp to not be out and about so i wanted to stick it under a the trunk mat and such
Old Jan 3, 2005 | 06:21 PM
2 Da Max's Avatar
o i hear ya, yea the amp dissapates alot of heat [learned that from slick] and its not good to cover it up, you could mess up the cooling system. btw go to home depot and by those cardboad type of wood sheets and use that its strong enough. and if you want throw some carpet on that bich. partsexpress.com has
Old Jan 3, 2005 | 06:27 PM
sachmo12345
i was thinking of cutting a piece of wood to fit in between the backseats and the trunk and then mounting the amp up on that
Old Jan 3, 2005 | 06:47 PM
AscendantMax's Avatar
just make sure the fins are vertical for better heat dissipation
Old Jan 3, 2005 | 06:59 PM
sachmo12345
fins?
10char
Old Jan 3, 2005 | 07:10 PM
sunten1
the heat sinks is what i think he means
you would mount this portrait and if you have the fins in the perpendiclar way you would mount it landscape
Old Jan 3, 2005 | 07:16 PM
Epacy's Avatar
Unsuccesful STL Coordinator
Don't put towels over it. Even in the trunk, or backside of the rear seat, the amp can heat up alot. It is best to get it as much air as possible.
Old Jan 3, 2005 | 07:18 PM
sachmo12345
my amp has no fins
Old Jan 3, 2005 | 07:42 PM
the sides are probably used as the heatsinks (fins)
Old Jan 3, 2005 | 08:19 PM
Scope's Avatar
Im izz sexay
Mount it to the sub box.
captchaos
Mar 15, 2016 12:18 PM
DayHeyZeus
Sep 11, 2015 03:17 PM
popdedop
Sep 11, 2015 11:17 AM
sdotcarter
Sep 2, 2015 09:53 PM
