4th gen amp ground?
Old Jan 4, 2005 | 11:44 PM
suprropmp's Avatar
4th gen amp ground?
It looks like I'm going to re-ground my amps tomorrow.. right now the ground cables are bolted to the metal thing that supports the back bench...
where is the best place for a ground?
Old Jan 4, 2005 | 11:57 PM
l3ftonm3's Avatar
good question, just make sure you strip any paint where you are going to ground it too.
Old Jan 5, 2005 | 01:09 AM
suprropmp's Avatar
any suggestions as to where?
Old Jan 5, 2005 | 08:33 AM
Micah95GLE's Avatar
I grounded mine to the big bolt that the lap belt bolts to underneath the rear seat (you have to remove the rear seat to access it). There's one on each side. It has worked perfectly and is hidden.
Old Jan 5, 2005 | 09:22 AM
Terran's Avatar
I'm going to have 2 amps, it's a bad idea to ground them both at the same place right?
It may not matter that much, but I'm going to get some of the stuff you can put on battery terminals (dielectric grease I think) that makes them not corrode to avoid rust where I strip the paint. May not even be a problem, but just a thought.
Old Jan 5, 2005 | 11:28 AM
Micah95GLE's Avatar
No, you should ground them at the same place if you can. Some people go so far as to ground all audio components (including the stuff in the dash) to the same grounding point in the car to avoid RFI. That's extreme, but if you can ground at the same place, do it. It might not make a difference, though. I never had any RFI in my 2 Maximas with 2 different systems.
Old Jan 5, 2005 | 02:01 PM
Terran's Avatar
Wow that was unexpected...what's RFI?
Old Jan 5, 2005 | 09:53 PM
l3ftonm3's Avatar
you could also get a grounding block to make it easier too. Run the 2 wires from the amps to the grounding block, then the one wire from block to the ground point.
Old Jan 6, 2005 | 08:06 AM
Micah95GLE's Avatar
Yep, that's a good idea.
RFI is radio-frequency interference. It sounds like noise through the speakers.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
iflexsteel
Sep 2, 2015 08:04 AM
Lowered_a33
Sep 1, 2015 07:49 PM
