remote start in 6 speed
Old Jan 5, 2005 | 10:43 AM
xarfox
is this possible?
dont you have to have your foot down on the clutch to start the car
sorry im new at this whole "manual" thing but it rules
Old Jan 5, 2005 | 10:53 AM
psu711's Avatar
Last year for xmas, I got my sister a remote starter for her xterra, Not impossible but complicated,
Have to always leave car in gear or something, cost about 500$ to get her a customized remote starter....Dont know all they did, but I think it was kinda complicated.
Took it to an advanced audio or some aftermarket audio shop...
Sorry for lack of deatils..
Old Jan 5, 2005 | 11:06 AM
psu711's Avatar
sorry @ work, can't think straight....Had to always leave the truck in neutral, with the emergency brake in place (obviously), so she could remote start it....
With a max, atleast a '02 you have to do the whole thing with getting another key, so they can install it under your hood.. The eltronic chip has to be close to your engine or something like that....back to the grind
Old Jan 5, 2005 | 11:13 AM
silvermax2k2's Avatar
yep, i have a remote start/alarm system in my max. i gave my friend at ciruit city $100 to install it, and 4 hrs later (due to some complications) it worked. ive had it for 8-10 months now, and i never remoted started it in gear.
Old Jan 5, 2005 | 12:33 PM
Matt_01SE_20th's Avatar
what you need is a trasponder chip permanantly mounted in the vehicle, a remote trigger for the cluch relay, and you need to remember to ALWAYS leave it in neutral. there are fail safes for the neutral thing but they are pretty complicated and expensive.
Old Jan 5, 2005 | 12:43 PM
Max6spd's Avatar
Yes, very possible...If you are a DIYr then you might want to PM "studman". He has done extensive documentation on the install procedure. I think it's on his web site but I forgot the site's name.
Good Luck...
Old Jan 5, 2005 | 01:23 PM
mistermax's Avatar
kinda OT but silvermax2k2 i was checkin out ur homepage and couldn't help but notice the pic of you installing a sway bar with your car lifted on the jack/jack stands in the GRASS?!? sorry dude u have a nice car but that was pure idiotic of you. ever hear of darwin?
Old Jan 5, 2005 | 01:26 PM
louisvuitton500
Originally Posted by xarfox
is this possible?
u can install an remote start on a stick. But u need to bypass the clutch and ur car must in in neutral at all times when u use ur remote start or ur car will go foward even if u have parking brakes on. If u have no or even little exprience on alarms, don't install it urself. You u end up ****ing it all up. I know someone that does alarms and remote starts for like $50 or less and does perfessional jobs but this ****ing dude will make u wait for like 3 month before he have time to install anything.....He custom mounted and fiberglassed 2 TVs for my previous car for $40 Total.....it woulded costed me $300 something at the shop he works in.
Old Jan 5, 2005 | 01:36 PM
xarfox
oh sorry guys forgot to mention i was gonna get it professionally done
i'll prolly buy it at tweeter, not sure if i want to install it there
just wanted to know if it was possible, according to some of the comments there might be additional costs but thats okay, i really want one integrated with an alarm
Old Jan 5, 2005 | 02:59 PM
kratz74's Avatar
Why would one need a remote start anyway?
Old Jan 5, 2005 | 03:05 PM
MiniRX7's Avatar
I have a Compustar remote starter. DO NOT INSTALL ANY AUTO TRANNY REMOTE STARTER ALARM INTO A STANDARD. It can easily be done, but man the risk of starting your car in gear is brutal.
My car has a manual reservation mode to ensure the car remote starts only in neutral.
Old Jan 5, 2005 | 03:13 PM
Igor911's Avatar
I have it done.
You need to connect the nuetral safety wire. PIN #44 ecu, green/white.
If the car is in gear then it wont start.
As for the clutch, there is a harness at the top of the pedal. Cut the 2 wires and splice them together.
Old Jan 5, 2005 | 03:38 PM
it was safer then it looks. I took all precautions insure it would fall on me.
Old Jan 5, 2005 | 04:29 PM
studman's Avatar
There is a safer way to do that. The remote start module has an "output when activated" wire that will send out a ground signal. You tap that wire to pin 1 of the Clutch Interlock Switch (not the black wire, but the other one) located just above the clutch pedal.
There are 2 switches located above the clutch pedal, so make sure you get the correct one. One of them will have a Light Green/Red wire and a Gray/Black wire. That is the wrong switch. Use the other one. The other one will have a Black wire, as well as another color wire. Tap the colored wire to the remote start's "Output when Activated" wire.
If done this way, in addition to the pin #44 wiring, the car will remote start as normal. However, using the method I posted, you cannot start the car using the key without engauging the clutch. Using Igor's method, you could start the car without using the clutch. This could be bad if the car was in gear and was started using the key.
If you ask why you would need to do it this way,... there are a few answers:
1) It's the correct, professional way
2) It's the safest way
3) You may not always be the only driver of your car everytime, and that other person could forget to engauge the clutch.
Old Jan 5, 2005 | 04:30 PM
1wkdmax's Avatar
Hay guys clifford makes a remote start kit just for standard. I have a 2003 se and i had it on for 1year and 7months and never had a problem. The way you set the remote start keep you from doing it in gear.Won,t set if you in gear.
Old Jan 5, 2005 | 04:41 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Ive installed dozens of them.
Car will not start/move when left in gear.
Immoblizor bypass goes under the dash not under the hood 'near the engine'.
Price is in the sig for Viper791/Clifford Matrix RS3.5
--Don
Old Jan 5, 2005 | 04:43 PM
Pearl96Max's Avatar
Good Luck...
Jeremy should share some of the credit
Old Jan 5, 2005 | 04:49 PM
Max's Max's Avatar
That how I installed mine. I also installed a pin switch on the clutch to shut off the car if the clutch is ever pushed in without the ignition key turned to the on position.
Old Jan 5, 2005 | 06:12 PM
max5spd's Avatar
Says.."No mo Maximas for me!"
Yup. I have the Clifford model as well.
Old Jan 5, 2005 | 08:49 PM
Igor911's Avatar
I've wanted to do this way, just never have any time to look into it.
MB this weekend if I'm bored.
Old Jan 6, 2005 | 01:25 AM
mistermax's Avatar
hey igor welcome back haven't seen u in a while here on the org.
Old Jan 6, 2005 | 10:14 AM
studman's Avatar
Read the site first, then PM me if you still have questions.
http://maxima.theowensfamily.com/
Definitely agree. And no one in their right mind is going to tell you where they placed the brain. That's not a very smart idea, especially on a public forum such as this.
And if you don't have a clue what all this means, please let a professional do it. If you are in the NJ/NY area, Pearl96Max is VERY VERY highly recommended as an installer.
Old Jan 6, 2005 | 02:52 PM
Igor911's Avatar
I'm here everyday....
I<3 A32's
Sep 10, 2015 11:07 AM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
