Where is a good place to drill for the Power wire?
Old Jan 15, 2005 | 02:57 PM
Andyman692's Avatar
I bought 27ft of 2ga wire and Im just wondering where a good place to drill is. Im only running like 700RMS but it was 30cents a foot at home depot : )~
Thanks.
Old Jan 16, 2005 | 08:49 AM
1996blackmax's Avatar
On the driver's side near the kick panel (go forward of the kickpanel area and up and you will see it)there is an area where there is a coutout on the rubber mat material that you can run it through. Just pull the "tab/cut out" off and you will see metal. You will also see a cutout on the other side on the engine compartment. I drilled a hole through the metal and ran my wiring through there. Good luck.
Old Jan 16, 2005 | 11:14 AM
Andyman692's Avatar
thanks, i drilled in a similar area, but it was a complete pain in the ***, even just for a 10ga wire. Ill look for the cutout on the engine side. Pics soon
Old Jan 16, 2005 | 05:40 PM
jzq's Avatar
jzq
why r u drilling when u dont need 2. theres a huge grommet in the driver side fender well.
Old Jan 16, 2005 | 05:49 PM
Terran's Avatar
You mean under the plastic fender guard? How do you get the wire from the engine bay into the fender well? I thought this was in the faqs, but I can't seem to find it.
Old Jan 17, 2005 | 12:41 PM
jzq's Avatar
jzq
There should be a hole in the engine bay that leads to the fender well. follow the wires and u should b able 2 find it.
Old Jan 17, 2005 | 10:55 PM
kpr10is's Avatar
Easier, faster...why would you want to run your wire through the fender well when you can run it straight to the engine bay without any hassle, and at the same time saving wire since it will use less.
Old Jan 19, 2005 | 06:58 AM
Big_Ham's Avatar
MaximaFreak
I ran mine closer to the center console. You need to drill a hole when you're using 4ga - 1/0ga.
My 1/0 Arc Welding cable (a.k.a. garden hose)
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
95Maxi
Aug 29, 2015 09:38 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
doobadoo
Aug 15, 2015 06:43 PM
