whats the best setup
Old Jan 19, 2005 | 03:33 AM
mclarengts1's Avatar
what the best setup for sound Quality (no 10s)
2 - 12s
2 - 15s
2 - 12s and 1 -15
Old Jan 19, 2005 | 06:26 AM
Big_Ham's Avatar
MaximaFreak
Never mix sub sizes. You risk cancellation. Different size subs have different wavelengths.
You're crazy not to consider 10's. They take up less room, cost less and can sound just as loud. That said, you will never get SQ out of 2 15's. 2 12's is the way to go if you simply refuse 10's.
Old Jan 19, 2005 | 02:49 PM
so should I go with 3 or 4 10's or will 2 do?
Old Jan 19, 2005 | 03:47 PM
Big_Ham's Avatar
MaximaFreak
Depends. Find 2 DEI CompX10's on eBay (there's one up right now for like $50) and you will be just fine with 2 10's. If you do three (which is sweet also), make sure you have an amp that can handle the load. 4 is overkill as far as available space (a 10's best quality is taking up so little space), but would obviously be louder.
Based on your consideration of 15's, I say 3 high wattage 10's with 1000+ watts (RMS) going to them. 3 x JL 10W6's will slam something fierce, same with those CompX's. 3 x IDQ10's would sound great, or if you could find them ... 3 x Infinity Beta 10's.
Old Jan 19, 2005 | 04:00 PM
thanks...
What does DEI stand for? also, Not questioning your knowledge, but does a sub for that price really sound that good? cause i have always been under the impression that you get what you pay for... i dont know alot about speakers thats why I ask
Old Jan 19, 2005 | 04:27 PM
1996blackmax's Avatar
A low price does not necessarily mean a bad sub. I actually got more than what I paid for. I bought a 10" sub (RL-i10 dvc) from Soundsplinter ( www.soundsplinter.com )for $159 dollars . The sub sounds really nice, very clean, and deep. I can imagine from listening to my sub, how nice two of these subs together would sound.
Old Jan 19, 2005 | 04:28 PM
Big_Ham's Avatar
MaximaFreak
Ugh ... and that's the problem. People get stuck on that and brand when it comes to subs and it barely applies. Meanwhile, for component sets and coaxials, it really does matter (although some cheaper sets will blow you away with how nice they sound).
When it comes to subs, any sub will sound awesome ... in the perfect box.
There are subs engineered, however, to handle more power, be more efficient, etc. These will not sound any better, per se, usually only louder ... in the proper box. It's mostly about the box.
DEI is Directed Electronics. Go to www.directed.com and see how many other brands they own. It's Orion, PPI, A/D/S/ and more ... their gear is not well known, but well made and for that reason, it goes cheap on eBay. All the kiddies are searching "JL Audio" or "Rockford Fosgate" or "Adire". I search "Infinity Beta", "Image Dynamics", "DEI", "Viper", etc. You can get a neodymium component set from Directed that will blow away many component sets out there for $100-$150 on eBay without a problem. Try finding Boston Acoustic's that cheap.
Old Jan 19, 2005 | 04:46 PM
oh ok cool I'll have to check these out I have heard of Image Dynamics, but not Adire.. so which DEI Component set do you recomend cause i need those too..
Old Jan 19, 2005 | 04:50 PM
Do you know any Directed Dealers... (for the moniters)?
Old Jan 19, 2005 | 08:28 PM
Big_Ham's Avatar
MaximaFreak
MMXpress.com is an authorized internet retailer for Directed gear. Check them out.
Old Jan 19, 2005 | 08:34 PM
joebangaa's Avatar
you could get 8's to get as loud and low as 15's... the first question is how much are you willing to spend. the second is how do you want it to sound (what are your musical preferences). third, how big of a box. that should narrow it down quite a bit
Old Jan 19, 2005 | 08:52 PM
AscendantMax's Avatar
Nothing wrong with Adire, they make some great stuff.
Old Jan 19, 2005 | 11:08 PM
slickrick's Avatar
if the kiddies who are 16 and searching for adire... they are light years ahead of me when i was 16. id put up an adire product up against anything when it comes to subs.
Old Jan 20, 2005 | 05:13 AM
Robert_J's Avatar
Putting any sub in it's "perfect" box will get the most out of it but comparing brand x to brand y or even different lines within the same brand will yeild different results.
First, you want a sub with low inductance. It's more accurate since less energy is stored in the voice coil. - woofer speed tech paper
Second, if you can afford it get a sub with a flat BL curve. There's more magnet strength throughout the excursion. There's a few ways to achieve this: XBL^2 and Linear Motor Technology (aka LMT) are just two.
Third, try to find some reviews or tests of the subs you are looking at. I pointed 1996blackmax to the TC2+ distortion test to backup my recommendation of the Soundsplinter subs.
Finally, if you can listen to a sub before buying, do it. While you are listening, find out about the install. Make sure the sub is in a recommended enclosure. See if they are running any bass boost or EQ. But don't rule out buying a sub without hearing it. You will find some excellent values over the internet.
-Robert
Old Jan 20, 2005 | 05:55 AM
Big_Ham's Avatar
MaximaFreak
Asking people to hear the subtleties in subwoofer output is an exercise in futility. I'm speaking of real world audible sound, not o-scoped output.
Example: Bazooka tubes are made with about the worst subs out there, but Bazooka found the perfect enclosure for them and consequently, they sound pretty good. They're not awesome by any means, but for what they are, I think they sound okay - some people would argue they sound "great".
Old Jan 20, 2005 | 07:13 PM
-Robert
I took Robert's advice, & I am very happy that I did.
I had one of my friends sit in my car today after work, and he was pretty impressed with the sound that the sub put out. My sister's boyfriend also liked the way the sub sounds (he said that it sounded tight and clean), he plans on buying a sub from Soundsplinter as well.
Old Jan 20, 2005 | 07:30 PM
Maxima Dan's Avatar
What's the rest of your system? How loud do you want it to be? How much are you looking to spend? How much space do you want left over in your trunk? What kind of music do you listen to? etc...
Everyone has their favorite brand of sub, so you're going to get lots of opinions here. If you gave us a bit more to go on it would be helpful. BTW I've always found 12s to be the perfect compromise between 10s and 15s.
Old Jan 20, 2005 | 07:41 PM
joebangaa's Avatar
LOL all of adires stuff is on par with ID. they are both super heavily concentrated on R&D. dan at adire and matt at ID work very ard and come up with very superior products. don't knock adire my friend, you'll be sorry
James92SE
142
Jan 2, 2024 09:23 AM
Apr 16, 2020 05:15 AM
knight_yyz
Nov 6, 2015 02:34 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
