Subwoofer help/advice needed.
Old Jan 22, 2005 | 02:50 PM
FormorAccordMan's Avatar
Okay, so here is the situation.
I run a single 10 inch kappa perfect in a 1.10cf slot ported box tuned to 34hz. The box is an awesome, made by sub zero. Anyway, I decided to experiment a little and stuffed the port tightly with a rag, essentially making the box a 1.10 cf sealed box. Now my kappa's instructions note a .60cf box should be used. essentially, my box is nearly double that. However, it sounds fantastic, no more boom and the deep end is nice and extended. Also, I really don't feel a WHOLE loss in SPL. Do i need to worry about the box being too big? What are the cons of running a box to big? .60cf is VERY small. What would I gain by putting it in a .60cf box as opposed to keeping it my 1.10 sealed? Thanks!
Old Jan 22, 2005 | 03:38 PM
AscendantMax's Avatar
the sub will be a bit more efficient on using the power its getting if it's in a larger box. low end extension will be better too in a larger box. imo, i'd keep it in the larger 'sealed' box.
Old Jan 22, 2005 | 03:57 PM
slickrick's Avatar
^^^ exactly. just make sure you dont blow it by overexcursion. but im a big fan of large sealed boxes...go play some late night tip and
Old Jan 22, 2005 | 04:59 PM
joebangaa's Avatar
i hate triple six
dv roxx-hardcore motherf*cker pounds crazy (and it aint no dirty southern rap)
Old Jan 23, 2005 | 09:43 PM
Thanks guys
litch
123
Jan 4, 2024 07:01 PM
sliptap
Sep 30, 2015 05:57 AM
