Need Relay experts
Old Feb 3, 2005 | 09:36 AM
tobe2be's Avatar
Need Relay experts
Ok here is the task. how can i hook up 2 relays so that i can turn off my car but my radio wont turn off until i open any door. BUT the radio cant turn back on when i close the door unless the key is set to acc or on
Old Feb 3, 2005 | 11:43 AM
djfrestyl's Avatar
Suspension Yoda
i know that in 5th gens if u kill the car your headlights only go off when you open the door, and wont go back on unless u put a key in....maybe tap the acc of the radio to the headlight relay
i could be completely wrong, though.
Old Feb 3, 2005 | 04:11 PM
kpr10is's Avatar
Yes, djfrestyl is correct. You need to tap the relay into the headlight wire from the steering column. You also will need a DMM to test the wire and whether it is positive trigger or negative trigger. Positive trigger rests at ground when the cars off and lights turn on when the wire sees 12 volts, negative trigger rests at 12v when the cars off and lights turn on when the wire sees ground.
Now...as for the relays. If the wire is negative trigger, hook up 85 to the headlight wire, 86 and 87 to constant power, 87a you can leave open, and 30 will be your output to the radio.
If the wire is positive trigger, hook up 86 to the headlight wire, 85 to ground, 87 to constant power, 87a leave open, and 30 will again be your output to the radio.
In either case you should put a 10A fuse in line to be safe
Good luck
Kevin
Old Feb 6, 2005 | 10:50 AM
tobe2be's Avatar
well i have a 91 maxima. there is a way to do it with 2 relays i just havent completely figured it out.
litch
123
Jan 4, 2024 07:01 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
zmcneely13
Sep 26, 2015 02:26 PM
