HU Problem
Old Feb 3, 2005 | 01:36 PM
nissanmax89's Avatar
HU Problem
i was looking at this HU http://www.crutchfield.com/S-49Ngrhr...f=N&search=jvc
but the auto fit option when you add it to the cart says it wont fit my 89 Maxima..what do i have to do to make it fit?
Old Feb 3, 2005 | 04:40 PM
kpr10is's Avatar
Thats a plain old single-din head unit. There isnt more than one size, theres single-din and double-din...but thats not the point...Crutchfield's guide is often wrong, like in this case, and that head unit will fit fine. Stop by your local shop, CC, or BB, and pick up a dash kit, wiring harness, and antenna adapter, and youll be good to go.
Kevin
Old Feb 3, 2005 | 07:53 PM
is there a special dash kit, wiring harness and antenna adapter i should get? or are they all just the same?
Old Feb 3, 2005 | 07:58 PM
kpr10is's Avatar
Depends where you get it from...theyre all the same just made by different companies. CC and BB, and a lot of places carry Metra, the biggest maker of stuff like that...it should be a 997401 dash kit, a 701763 wiring harness, and 40NI10 antenna adapter. At CC, dash kits are $17, harness are $17, and antenna adapters are $12.
Kevin
Old Feb 3, 2005 | 09:48 PM
OneToughMax's Avatar
you don't need a dash kit for your car - it's iso din. just use the oem iso brackets.
Old Feb 4, 2005 | 09:56 AM
generation3's Avatar
If you use the OEM brackets you wont be able to put the trim on. Do you have the cassette player? cassette player with cd?
Old Feb 4, 2005 | 01:15 PM
Intel's Avatar
no need to have the trim unless you are mounting it in like a GM or some other old car where they didnt have dins so you had to like cut out the dash etc.
When I put in my pioneer in my 3rd gen I just put it in the frame and it fit just fine. Only pain was getting out the screws without stripping (get largest phillips you can and put all your weight on it). It did push forward a little so it wasnt flush etc but it fit just fine without anything more hten just the antennae and wiring harness.
Old Feb 4, 2005 | 02:59 PM
there's a trick to pulling out the philips screws without stripping them: just tighten them first - give it a turn clockwise and it will break free, then loosen it up. works every time. just use a #2 philips. if you use anything smaller you're going to strip them for sure and have to drill the screw heads off..
Old Feb 4, 2005 | 08:31 PM
how does tightening them first help them
Old Feb 4, 2005 | 09:27 PM
kpr10is's Avatar
+1 Im curious how that works onetoughmax...cuz in my experiences, the screws are stuck in place so either way you hafta break them loose in either direction. The ones that I have stripped, my Dewalt 14.4v takes care of them real quick
Old Feb 5, 2005 | 07:42 AM
Black Maxima
Try this: Put the screw driver in the screw head, then tap on the screw driver a couple times hardly. You should be able to loosen the screw now.
Old Feb 5, 2005 | 09:19 AM
i basically took apart my entire dash and i think one screw gave me trouble, other than that everything else was fine, but ill keep that in mind thanks
Old Feb 5, 2005 | 10:43 PM
i don't know the exact physics of what happens, but i've been using that trick for years and it never fails.. maybe don knows that trick too and he can tell us how it works...
don?
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
