indiglo gauges
Old Feb 4, 2005 | 12:23 PM
SDB318's Avatar
indiglo gauges
just bought gauges but i dont know how to get power to them. i have this gay cheap plastic push button, i dont what to use it if i dont have to. i drew a picture of what it looks like
Old Feb 4, 2005 | 05:14 PM
kpr10is's Avatar
lol good diagram...well the red is power and black is ground. Ground the black wire anywhere, and then gauges will turn on whenever that red wire has power, so if your good at taking your car apart, you can find the wire coming off the steering column that turns on the headlights, and wire power to it. You might want to put a fuse in line to protect your gauges too. See the sticky at the top of the Audio forum for wiring info for your car, which will be the same as the wiring info for the 1997 posted in there.
Kevin
Old Feb 5, 2005 | 07:40 AM
SDB318's Avatar
what about that push button thing
Old Feb 5, 2005 | 11:57 AM
SDB318's Avatar
can anybody help me
Old Feb 5, 2005 | 06:08 PM
kpr10is's Avatar
what is this button? youll have to test it out, it might just be an on/off switch, so that you can just hook it up to a constant or switched power source without going under the dash for the headlight wire. When I had my indiglos a while back, I was lazy and tapped it into the radio illumination wire (wire that turns on your radios internal lights with the headlights), so theyd turn on with the headlights. then i had a little switch like that one you speak of, but it had no wires i needed to connect. it was just a switch for blue or green, and brightness.
Kevin
Old Feb 6, 2005 | 03:02 PM
SDB318's Avatar
yea but mine is an on/off button but is there away they can just turn on when i turn my headlights on
Old Feb 6, 2005 | 07:58 PM
kpr10is's Avatar
yes just wire it up like i said two posts above, to the headlight wire, then leave the switch on.
Old Feb 6, 2005 | 08:46 PM
SDB318's Avatar
its a button not a switch. so if for me to wire it up to the headlights then i would need to take the steering column
Old Feb 6, 2005 | 10:42 PM
kpr10is's Avatar
yes, and an english lesson wouldnt hurt as you are missing some words
Old Feb 7, 2005 | 06:40 AM
SDB318's Avatar
alright i will try doing this tomorrow
Old Feb 7, 2005 | 07:55 AM
96mAx2fast's Avatar
That little butto might be to toggle between the colors.. Good luck
Old Feb 7, 2005 | 12:19 PM
SDB318's Avatar
my gauges dont change colors and it says on/off on it
Miket2006
Mar 1, 2021 03:55 AM
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
kadespraggins
Sep 14, 2015 12:04 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
