Door sound deadening ?'s
Old Feb 7, 2005 | 02:38 PM
Slow Moe's Avatar
When sound deadening the door did you reapply the plastic liner inside the door panel? Is there any risks on not putting it back on? (rust).
Old Feb 7, 2005 | 02:57 PM
MannyNJ2k2max's Avatar
the plastic liner is there to keep water/moisture that enter the doors away from the door panel and connections- you should reapply it
Old Feb 7, 2005 | 03:45 PM
Slow Moe's Avatar
Thanks for the quick response, Manny.
Old Feb 7, 2005 | 06:22 PM
KCMaxima98's Avatar
Are you going to do the whole door? Wouldn't it be ok just to do behind the speaker? I know doing the whole door would probably reduce road noise but Im just looking for a little more punchiness in the mid-bass. I have seen those dynamat sheets that are sold as accessories with speakers that just apply to the area behind the speaker. Would that do the trick? I really don't want to deaden the whole door...and dynamat is sooo expensive.
Im trying to figure this out before I get some components for the front so I don't have to pull the door panel off more than once more.
Old Feb 7, 2005 | 06:37 PM
fishpony's Avatar
search for something other than dynamat. You can find other cheaper alternatives
Old Feb 7, 2005 | 08:20 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Dynamat for sound attenuation is what JL Audio is to the mobile stereo market - effective but highly overpriced. There are a number of good alternatives, do a search for Brown Bread, peel 'n seal, rammatt, eDead, and a host of others I am sure I am forgetting. I have also heard of people using shelf liner as an alternative to the aforementioned products, but I don't see this as being a viable recommendation as [it] will not be suited to dampen rattles that may occur due to an increase in vibrations.
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
