2k3 Base System?
To do it right you need a 30 amp relay you need to cut the switched pin of the relay to an ignition wire andn you need to conect to constant power to the constant pin and ground the other two pins. If you want to do it wrong you can just connect an ignition wire as the remote wire but i suggest you use a fuse so you dont damage anything.
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
