i need a capacitor.....
Old Feb 13, 2005 | 10:23 PM
  #41
machinehead's Avatar
phatone--you need a bigger alt. 2k is a lot.
Originally Posted by BustaReims
Caps are totally worthless...look at the majority of SPL and SQ competitors, you will not find a strike cap, but that is not to say the the alternator has not been upgraded.
SQ cars are judged while the car is not running But you are correct, no one uses caps!
Old Feb 13, 2005 | 10:50 PM
  #42
thephatOne's Avatar
i cant actually afford a bigger alternator at the moment, they go for around 400 correct?
Old Feb 14, 2005 | 04:23 AM
  #43
2 Da Max's Avatar
you have a 2k max and you need a new alternator already?
Old Feb 14, 2005 | 05:44 AM
  #44
Pearl96Max's Avatar
I tend to get a bit irritable
A stock alternator cannot produce enough to feed 2200 watts. The age has nothing to do with it.
Old Feb 14, 2005 | 09:22 AM
  #45
2 Da Max's Avatar
^^^^ ooh i see. so how about how much do you think a stock altenator with 125 amps can handle? 1000watts?
Old Feb 14, 2005 | 11:29 AM
  #46
Pearl96Max's Avatar
it all depends on efficiency of the amp. Somewhere around that area at peak output from the alt with a 50% efficiency rated amp
Old Feb 14, 2005 | 11:58 AM
  #47
ZIPPIN's Avatar
Mauja He Mauja
choices on Am alternators??
Old Feb 14, 2005 | 12:25 PM
  #48
Pearl96Max's Avatar
Ohio Generator would be my first choice, Stinger secondly. I was gonna run a GD on either of these, but it didnt seem the interest was there....
--Don
Old Feb 14, 2005 | 12:29 PM
  #49
Torgus's Avatar
a quick google came up with this...
http://www.highoutputalternator.com/
http://www.americanarmature.com/partcatolog.htm
http://www.zena.net/htdocs/alternators/alt_inf.shtml
http://www.alternatorparts.com/Extre...144%20type.htm
Old Apr 20, 2005 | 07:55 PM
  #50
stevepow's Avatar
Capasitor help
Ok here is the deal im going to buy the kenwood Kac-7201 amp i had it before and it never gave me a problem i will run it bridged to give me 460 RMS
i will be using it on the Kicker Solo-Baric VS10L5-4. It will be wired up using 8 awg wire. I just got a new altinator and batt about a year ago. My question is am i going to need a cap i just have one amp running one sub. I used to think no matter what amp you have you will always need a cap but now im reading diffrent things. Now i drive a 91 mercury tracer Im not trying to blow the window and doors off of my car i just want a really nice base that i will be happy with maybe even being heard up the block with out having to worry that im going to need a new altinator or Batt every other week. Please be honest thanks :
here are the sites for the amp and the sub
(amp) http://www.etronics.com/product.asp?...201&svbname=30
(Sub) http://www.cardomain.com/item/KIC05VS10L54?ref=deal
Old Apr 20, 2005 | 08:04 PM
  #51
AscendantMax's Avatar
i'd just save the money. you don't need a cap with only 460 watts.
Old Apr 21, 2005 | 05:16 PM
  #52
stevepow's Avatar
Ok to day i was talking to someone at circuitecity now the amp that im going to get is 460 RMS 800 watt peak and the sub is rated at 550 RMS would this be a big loss and will the missing 90 RMS do any damage to the sub
Old Apr 22, 2005 | 06:00 PM
  #53
you don't have to send the sub with gobs of power to make it sounds good. what size box are you using?
