hey screeching sound
Old Feb 15, 2005 | 11:15 AM
Assassinroon's Avatar
Hey i turned my car on today and there is this schreeching sound coming from the speakers. The speakers still play but i am hearing this horrible screech coming from the 4 speakers. Today i found my found was fading in and out and now this screech noise is here!
I have a kicker 2 channel amp and component speakers in the front deck and coaxials in the back...Both aftermarket type s speaks thanks !
Old Feb 15, 2005 | 02:09 PM
AscendantMax's Avatar
does it fluctuate with engine rpm? i'm guessing its a bad ground somewhere.
Old Feb 15, 2005 | 06:40 PM
2 Da Max's Avatar
sounds like bad grounds, i would hear a clicking noise when i moved my seats [electronic] in the speakers.
Old Feb 15, 2005 | 08:54 PM
Tony Fernandes's Avatar
If it's not fluctuating with the engine RPMs like Fosgate Fan asked, you might also want to check your RCA cords and the RCA connections to the HU and the amp. This might also explain why the sound is fading in and out.
Tony
Old Feb 16, 2005 | 10:08 AM
hey guys it is in tune with the RPM when i speed up the noise gets louder. Does this mean my ground wire needs to be changed?
Old Feb 16, 2005 | 11:09 AM
hey checked my ground wire in the amp too its fine but the noise is still coming
Old Feb 16, 2005 | 11:22 AM
slickrick's Avatar
where is the amp grounded to?
Old Feb 16, 2005 | 11:30 AM
underneath the carpet above the tire drilled right into that metal
Old Feb 16, 2005 | 12:28 PM
my99maxisnice's Avatar
Is that area painted? If so, sand it down.
Old Feb 16, 2005 | 12:35 PM
there was not this screeching sound before though why all of a sudden?
Old Feb 16, 2005 | 12:54 PM
you should check the connections behind your HU. That might make sense as to why it just all of sudden happen, if an RCA came loose.
Old Feb 16, 2005 | 12:59 PM
slickrick's Avatar
^^^ we're working on that. go buy an atlas already.
Old Feb 16, 2005 | 01:15 PM
sub needs power doesn't it?
Old Feb 19, 2005 | 02:24 PM
Update
Check grounds sanded them down
Checked h/u grounds
Tried the Alternator Filter from radio shack
Check all wiring
Im still getting the noise !!!
Old Feb 19, 2005 | 02:45 PM
BRINKLEY's Avatar
I think I would try moving the ground to a different place. Also, when you ran your wiring, did you run your speaker wires or rca plugs next to your battery wire to your amp? If so, this can cause noise. I would bet its the ground though, I'd try moving it to a different place first. One more thing, if you have power coming from the fuse panel, might want to try a different fuse.
Old Feb 19, 2005 | 03:15 PM
hey update again lol i move teh ground wire its still doing it . the jbl amp works perfectly fine that i run the subs on only the kicker amp for the interior speakers are macking noise
Old Feb 19, 2005 | 04:14 PM
BRINKLEY's Avatar
I think if I were you I would try the jbl amp on the interior speakers. Then go from there.
Old Feb 19, 2005 | 04:33 PM
slickrick's Avatar
no!!! its a class d amp and cannot be used for components not even taking into account that 300 watts per side would murder his comps. hes already been instructed to used the KICKER amp to run the subs with and see if its a wiring issue,
Old Feb 19, 2005 | 05:32 PM
BRINKLEY's Avatar
ok, I didn't know it was a class D amp. anyway, I didn't mean for him to crank it up, just try and see if the screeching was still there. I've had trouble like this before and I'm just trying to help the guy.
Assassinroon- only other thing I can think of is maybe a bad rca plug. I've had it happen to me once, and I sent my amp off to be fixed, they sent it back, charged me $150 and come to find out, it was an rca plug. Now I troubleshoot before sending anything off. Good luck.
Old Feb 19, 2005 | 05:34 PM
slickrick's Avatar
no problem. i just did not want him to read this and do it because he wanted to do that also but i told him to use the kicker amp on the subs. i still think its somewhere in the integrity of the install...
Old Feb 19, 2005 | 05:49 PM
BRINKLEY's Avatar
I feel for him, been there and it sux. Last time it happened to me, had my truck tore APART for 10 hours. finally found it though. very frustrating.
Old Feb 20, 2005 | 11:25 AM
max_on_17's Avatar
i have the same problem with my max too. i have a (pioneer deh-ph4600mp) head uint and two power acoustick's amp's.the one running my sub's is a (820 watt) and the one running my high's is(620 watt's). i have moved my ground's ran new rca cables.new 4 ga power wire,new 4ga ground wires.new speaker wires . i am lost .......when the car is off nice sound ,when the car is running man it suck's to here that nosie comming from my mid's and high's. i have my 620 all the way down .so can some one please help me . i love my tump but if i can not get this out i will pull it all out and get ride of it all.oh and the head uint is new and so are both amp's and sub's and mid's and high's..i even put new ground wires on the battery and on the motor. i used 4ga on both.
Old Feb 21, 2005 | 06:05 AM
ramtaajogi's Avatar
i have the SAME prob, but i didnt even install an amp yet. its coming from my rear stock speakers, which are going to be replace anyway, but i dont want this noise coming when i install new speakers. by the way, when i was installing my front speakers i tore off the adapter and the wire was a bit short, so i just used regular home speaker wire to extend it, is that ok, or do i need to buy car audio wire cuz it might be shielded.
Old Feb 23, 2005 | 06:52 AM
okay update guys the rca cables are fine, everything else is fine lol Still getting the noise. Plz some audio heads get in here try to help me out
Old Feb 23, 2005 | 07:41 AM
You said earlier that the noise is in tune with the engine and gets "louder" when you rev the engine. Do you actually mean it gets louder, or that the pitch goes up and down with the engine rpms?
You also wrote: "Today i found my found was fading in and out and now this screech noise is here!" What do you mean your found (sound?) was fading in and out? Did you resolve that or is that still a problem too?
And finally, is it truly a screaching sound, or just a whine?
If it's alternator whine, then it's most likely a poor ground. I guess we need more info, if what we've been suggesting is not working.
Tony
Old Feb 23, 2005 | 08:10 AM
okay tony ill give ya some answers
The pitch goes up with the rpms isnt that the same thing as getting louder?
Yes sometimes my sound fades really low but that has stopped for now
And its more of a whine so im guessing its a alternator whine.
I check the grounds on the amp sanded them down and the head unit ground is fitted. What else cna i do ?>
Max139617
Oct 19, 2016 11:34 AM
RinconI30
Nov 10, 2015 10:55 PM
popdedop
Sep 11, 2015 11:17 AM
DrVee
Sep 4, 2015 12:18 PM
sdotcarter
Sep 2, 2015 09:53 PM
