will this setup work
Old Feb 22, 2005 | 11:53 AM
ramtaajogi's Avatar
i have a hifonics 4 channel amp. i am going to set it up 55x4 and use 2 channels for my front speakers and use the remaining 2 for my subs. i will get 110 watts for my sub and im getting a 12 inch rockford fosgate stage 1 with 150 rms. will that work fine? or is my thinking/understanding wrong.
also, does it REALLY matter what amp install kit i get. i need a 4 gauge and i got a cheap audiopipe amp install kit for 25 bucks.
Old Feb 22, 2005 | 12:01 PM
Matt93SE's Avatar
STFU n00b!
If that's your only amp, then you'll be fine with the audiopipe kit. their 4awg is about the size of most brands' 6awg.
the biggest difference in those kits is the size of the wire. Monster cable 4 awg is the biggest stuff I've seen. I can BARELY cram it in a 4 awg connector. ATS (Amp King), Streetwires, Scosche, and the other major brands all have good wire as well.
As for your setup, what's the model # on the amp and the impedance of the sub?
how's the bridged output on that Hifonics at 2,4,8 ohms- or whatever it is on the sub.
at 110W, the sub won't be incredibly loud, but it'll work... I have a feeling your HiFonics will be putting out more power than that in bridged mode.
Old Feb 22, 2005 | 12:24 PM
ramtaajogi's Avatar
my amp is hifonics zx4400 amp. and the sub has a 4 ohm impedance.
4 x 55 Watts @ 4 ohm
4 x 110 Watts @ 2 ohm
2 x 220 Watts @ 4 ohm Bridged
yea its 220 watts bridged. so i can get a 250 rms sub right.
sorry to ask a stupid question, but can i put two 150 watts subs to get the 300 watts,which is less than 250 rms. or does each sub have to be 250 each.
Old Feb 22, 2005 | 12:41 PM
machinehead's Avatar
250rms is just the limit. You don't have to give it that exact amount. Just get one sub that can handle 250 watts rms and comes with a single 4 ohm voice coil or a dual 2 ohm voice coil.
That wire kit should be big enough for that amp. As for subs, get an adire shiva for $125 shipped, should suit you fine.
Old Feb 22, 2005 | 01:13 PM
ramtaajogi's Avatar
also, does it matter alot what kinda box do i get, or its not the best place to froogle
Old Feb 24, 2005 | 10:14 PM
ramtaajogi's Avatar
like i said i was going to do a 2 x 55 and a 2 x 220 bridged for my sub. what if i put in 200 watt subs would the speakers get damaged? a guy by my house is selling these from his daughters car..they are dual rockford fosgate RFZ2412 in a qlogic box $40 bucks., i no the subs are old, but they sound pretty good for my use.
Old Feb 25, 2005 | 08:21 AM
ramtaajogi's Avatar
nope...u cant have a sub rms less than the amp. answered my own question
Old Feb 25, 2005 | 08:41 AM
swowlinc's Avatar
1993 SE
The box makes a BIG difference. Do not be froogle. Also power ratings depend on the size of the box not just rms. for instance, if u have a 1000watt rms sub and the specs state that optimum sealed enclosure is anywhere from 1.0 cu. ft- 3.0cu.ft, then do not get the 3cu ft box AND give it the full rms rating. As much as you go up in box size, you should step down the rms a bit.
Old Feb 26, 2005 | 07:20 PM
ramtaajogi's Avatar
when choosing interconnect rca cables does brand really matter. i see cables for 5 bucks for 17 feet and i see cables for 40.
Old Feb 26, 2005 | 07:40 PM
slickrick's Avatar
i run 2 sets of walmart rcas with no problem...
Old Feb 26, 2005 | 07:47 PM
ramtaajogi's Avatar
these are the specs of the woofer im looking at. i want a small box with tight accurate base. will this work on my hiphoncs amp listed above gettign 2 x 220 Watts @ 4 ohm Bridged
AUDIOBAHN AW1051SE 10" 300W
» dual 4-ohm voice coils
» frequency response 28-1,000 Hz
» power range 50-300 watts RMS (150 watts per coil)
» peak power handling 600 watts
it can be wired for 2-ohm (coils wired in parallel), 8-ohm (coils wired in series), or 4-ohm impedance (each coil wired independently).
Old Feb 26, 2005 | 07:48 PM
slickrick's Avatar
i highly recommend getting something else especially since it sounds like you want good sq.
Old Feb 26, 2005 | 08:42 PM
Pearl96Max's Avatar
I tend to get a bit irritable
And you are soooo proud of that
Old Feb 26, 2005 | 08:44 PM
slickrick's Avatar
gotta rep the college budget!
Old Feb 27, 2005 | 08:30 AM
ramtaajogi's Avatar
similar to slickrick..im on a tight college budget as well...ne thing u guys recommand that i can pick up on ebay for max 120 with enclosure. just wanting accurate base. nothing massive.
Old Feb 27, 2005 | 07:23 PM
MrSector9's Avatar
for that much money look for a kenwood bass cannon.. I had an 8" one and mind you it was nothing earth shattering but it was a good sounding unit,Had the amp on it,small ported enclosure... i see them sell for $100 canadian and new they soold for $300 canadian..
Also it sounded way ebtter then bazooka's brand or any of the other bass cannons i had heard..
BJ White
Old Feb 28, 2005 | 08:49 AM
ramtaajogi's Avatar
someone at school is selling a Kicker S12L7 in a slanted enclosure. he says he used it for a year and still sounds good. $100...is that a good deal and its says 100 - 750 RMS..im only gonan give it 220. it wont work at optimal, but will it still work good.
Old Feb 28, 2005 | 08:13 PM
ramtaajogi's Avatar
or is getting something rated closed to my amp wattage better
Old Mar 2, 2005 | 09:56 AM
ramtaajogi's Avatar
ne word on audiobahn AW1051SE. its a dual voice sub with 300 rms. having these in a 10 inch sealed box fed by a 220 watts should be ok right. i never heard ne audiobahn subs, u guys got ne feedback on it.
Old Mar 2, 2005 | 09:57 AM
ramtaajogi's Avatar
they are only $35.00 on ebay with local pickup.
Old Mar 2, 2005 | 10:06 AM
Pearl96Max's Avatar
Audiobahn = All bling, no sing.
You get what you pay for...
Old Mar 2, 2005 | 11:42 AM
swowlinc's Avatar
1993 SE
These are ok. Not great though. these are the lower series of Audiobahn subs and if you give them their rated power, the tinsel leads will pop.
Old Mar 2, 2005 | 03:49 PM
ramtaajogi's Avatar
ill scratch that then. damn i need subs..i got my highs installed for 1 week now and hate driving with just highs.
Old Mar 2, 2005 | 07:45 PM
ramtaajogi's Avatar
first let me thank you guys for helping me along my new system. cruthfield has the 10 inch Infinity Kappa Perfect10 VQ with 75-400W RMS power range • 25-400 Hz frequency response. these are a bit cheaper than ebay and feels good knowing your product has warranty. im worried if i get this sub,my 220 watts will not be enough for this. but then again leaves me with future room to upgrade. will i still get good bass even though im giving it 1/2 the wattage. im going to be putting it into a sealed box.
Old Mar 2, 2005 | 07:48 PM
slickrick's Avatar
yes ive read they are sensitive speakers and do not like more than the rms rating anyway. if you'd like more output go ported.
Old Mar 2, 2005 | 07:50 PM
ramtaajogi's Avatar
also, the box range is .3 to 1 cu ft. the smaller the box the more power is needed. am i seeing that right? i was just gonna get a .36 type 1 qlogic box.
Old Mar 3, 2005 | 07:36 AM
Wil's95SE's Avatar
我爱台湾
You said that a guy at your school was selling a 12L7 for $100 used? You could get it and use it but I know for a fact that the amp you are trying to use won't be enough to push that kind of sub. That's a good deal on that L7.
Old Mar 3, 2005 | 07:40 AM
ramtaajogi's Avatar
i brought the 10 inch Infinity Kappa Perfect10 VQ with 75-400W RMS from cruthfield today for 120. hopefully my 220 watts bridged will push this sub ...if not...they have a return policy and hopefully they will take it back. i wanted 400 cuz i might expand in the future to a mono sub. never knew car audio was this hard. well its hard when your trying to get maximum performance for your dollar.
Old Mar 3, 2005 | 07:56 AM
Pearl96Max's Avatar
Since your local I could have put you into a DA CM3 12 or Arc KAR12 for that money....
--Don
Old Mar 4, 2005 | 06:39 AM
ramtaajogi's Avatar
thanks for the offer don.
im worried about underpowering my sub. is 220 watts far to less to give a 400 rms sub. i dont want to damage it due to clipping. is there a simply setup i can set on teh gain, etc that i will not damage my sub.
Old Mar 4, 2005 | 07:22 AM
slickrick's Avatar
id take a cm3 over that sub along with professional help with the gain setting.
you set your gain based on your h/u's voltage. however, each h/u has different max volts it put out (and some like eclipse do it cleaner than others which also matters), so for what yuo are working with, id either do the 3/4 volume method or if you have an osciliscope (sp?) handy look for distortion. but there is nothing wrong with running the sub at less than rms, rms is simply a guideline. if you still are feeling so gulity about not giving it enough power increase the box size to get that low end extension, at a slight loss in "punchiness".
Old Mar 4, 2005 | 10:34 AM
I'd take don's offer, that way it's done right
Old Mar 4, 2005 | 05:02 PM
ramtaajogi's Avatar
don does your price include an enclosure? and does cm3 fit into the small sealed enclosure becuase i need to have truck space left over and cannot have a big box in there. thanks.
Old Mar 4, 2005 | 05:09 PM
ramtaajogi's Avatar
i see that the cm3 is 500 rms. wouldnt that put my sub/amp rms ratio even greater. ill see how the infiniti sounds cuz i have 30 days to return it back to cruthfield. i like infinity products. u think some local shop can set my sub for me. if so how much could they charge. as you can see i am in fear of blowing the sub.
Old Mar 4, 2005 | 06:07 PM
Pearl96Max's Avatar
No, sorry not at that price niether of the subs would include an enclosure. Both the Arc KAR and the DA CM3 are designed for small enclosures. Aside from that, a 3 year warranty on a higher quality product is just a perk.
Old Mar 5, 2005 | 10:03 PM
ramtaajogi's Avatar
im thinking of getting an amp just to push my 400 rms infinity sub. i got a hifonics 4400 and i dont want to run a second power cable. i just want to use a fused distribution block to give power to both. im thinking since i used a 4 gauge wire already to power my 4 gague connectors on the hifonics that a fused distribution block will not work for me. is this correct?
Old Mar 5, 2005 | 10:27 PM
ramtaajogi's Avatar
i was thinking of using a Hifonics Zeus ZX4000 a 2 chan bridged will give m 400 rms for my sub. i never heard of hifonics (but than again i just started reading car audio a few weeks ago) and I am fully pleased with my zeus 4400. hope i can connect this without running a second power wire.
Old Mar 6, 2005 | 07:02 PM
ramtaajogi's Avatar
the fuse on the zx4400 is 50 amps and the zx4000 is 40 amps. i think a 4 gague wire can run 100 amps of current so i think i will be ok. are there any places that will sell me 4 gague power cable by the foot?
Old Mar 7, 2005 | 07:58 PM
ramtaajogi's Avatar
bump.. set..spike.
Old Mar 9, 2005 | 06:45 PM
ramtaajogi's Avatar
please ..anyone. i have the goods, just need the ok to install it.
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Hailstatejig
Sep 2, 2015 06:52 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
