Best place to ground amp in car
Old Feb 28, 2005 | 01:09 AM
BuNGsVQ's Avatar
I was wondering where the best place was to ground my amp that's located underneath the passenger seat. I can't seem to find a good spot to bolt down my 8 gauge wire.
Old Feb 28, 2005 | 06:00 AM
ShRapNeR's Avatar
rear stut mount bolt...
*EDIT* since its in the car.. you can prolly use the seatbelt bolt
Old Feb 28, 2005 | 06:01 AM
ShRapNeR's Avatar
and in all honesty i would use 4g wire or bigger
Old Feb 28, 2005 | 06:15 AM
Pearl96Max's Avatar
I tend to get a bit irritable
rear strut and seatbelt bolt are two of the places to avoid. Strut bolt can cause to much friction and seatbelt bolt is typically covered in threadlock, which could lead to a bad grounding point.
Just make your own and make sure you grind/sand down the metal prior to installing...
--Don
Old Feb 28, 2005 | 08:29 AM
MrSector9's Avatar
You could use one of the seat bolts but make sure you bare the metal really good and put some dielectric grease on there since you dont want the bolt to rust in.
As far as using 4g that is WAY overkill depending on how long the cable will be run and also the power of the amp. 8 gauge will support 600 wat rms up to a 3 foot length.
BJ white
Old Feb 28, 2005 | 01:18 PM
sachmo12345
take out the carpet and there are some screws in the metal of the trunk
Lakersallday24
Jun 16, 2019 01:35 AM
2k11ApexEvo
Mar 30, 2016 06:54 PM
acw
Aug 13, 2015 12:50 AM
erniel
Aug 8, 2015 09:32 AM
