I Need Help!!!!
Old Mar 8, 2005 | 05:45 PM
suckafree823's Avatar
I Need Help!!!!
i need help...i was installing my amp, after i tightened the negative and positive power cable to my cap i dropped the wrench and it fell onto the cap and it touched both the positive and negative terminals and *FLASH* sparks flying and now my amp doesnt work, it powers on but no sound
Old Mar 8, 2005 | 05:46 PM
2 Da Max's Avatar
is there a power protect on the amp? i used to see sparks all the time on my amp and cap, its nothing really. once it lights up the normal color it should be good. was there sound comming out of it before?
Old Mar 8, 2005 | 05:56 PM
my99maxisnice's Avatar
This does you no good now, but always disconnect the neg. terminal of the battery when working on dat shiet.
the green led light is on, the red led protect light never went on...i bought it second hand and when i got it the guy showed me and it was working
Old Mar 8, 2005 | 05:57 PM
it was disconnected
2 Da Max's Avatar
what brand amp do you have? there is a possibility you shorted it out, check your fuses, no wait it turns on right, check your sub
Old Mar 8, 2005 | 05:59 PM
its a kicker 600.1, i hooked up my old junk amp and it works
Old Mar 8, 2005 | 06:15 PM
2 Da Max's Avatar
oo no not the kicker, this also happened to someone previously on the org with that same amp, kicker amps are suppose to be good though
Old Mar 9, 2005 | 08:27 AM
merovi's Avatar
ya something like that happened to me. I had the kicker 600.1 with 2 12" kicker comp vr's. some how they were wired in and ohms were too low and i had no idea. It worked fine for months..almost a year i think then 1 day *poof* smoke everywhere and it shorted out. Then i blew a fosgate with 500 rms the next day because i had no idea it was the subs. worst 2 days ever. but anytime u see sparks its no good. check the fuses in the amp. if you saw any smoke at all from the amp..say good night.
Old Mar 9, 2005 | 08:53 AM
djfrestyl's Avatar
Suspension Yoda
sorry - still trying to get past this. im at a loss for words on this one
on your amp though - fuses (internal and external) and power protect. some even have a breaker to reset.
Old Mar 9, 2005 | 08:54 AM
djfrestyl's Avatar
Suspension Yoda
Old Mar 9, 2005 | 08:46 PM
fuses are good amp didnt smoke, just sparks from the cap, im not able to check internally, wut did u do wid ur amp?? im thinkin of sending it in to get it repaired...
Old Mar 9, 2005 | 09:16 PM
djfrestyl's Avatar
Suspension Yoda
try bypassing the cap and use a direct wire for the amp.
use a meter on the speaker terminals to see if ure getting anything
Old Mar 10, 2005 | 04:50 PM
merovi's Avatar
my subs were wired in at a too low of an ohm state and the amp coujld'nt handle it and it smoked...alot
