fiberglassing.....
Old Apr 4, 2005 | 08:55 PM
maxspeed96CT's Avatar
The original VQ...
fiberglassing.....****UPDATEDED***** PICS!!
TEST FIT
i started my fiberglass box today.
i got the first layer/shell layer done.
Im just wondering how many coats of the mat do i have to put to make sure this thing will be strong. 4-5?
Also, i got a few bubbles in the fiberglass, the spot is still strong but i can see air pockets, can i just cover these up or did i screw up??
o ya i am putting the box in the left rear corner of the trunk and im gona be pushing 1 12"
most recent pics!!
Old Apr 5, 2005 | 05:57 AM
MacAlert's Avatar
Old Apr 5, 2005 | 03:20 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
2 Layers, followed by a layer of body filler. Sand down the body filler ($15, Advance) using a filler knife ($1.50, Advance) and 200-grit paper. Then add a final layer of mix that consists of even amounts resin and body filler mixed together - this will give you a pourable mixture that is easy to sand. If you go with just fiberglass it is going to take longer and not give as strong a final product. For the extra $20 it's 110% worth it.
Unfortunatley, yes. To remove the air bubbles, pop them out with your brush - this process is called "stippling". As far as the existing bubble are concerned, just sand that part down...it's not going to go away if the resin has cured.
Good luck!
Old Apr 5, 2005 | 03:22 PM
Conrad283's Avatar
I need a truck
No pics, no care.
Old Apr 5, 2005 | 04:22 PM
95bkackmax18s's Avatar
oh boy, fiberglassing is fun, aint it? pop those air bubbles and put some filler in there and have fun sanding away. get some pics up if you can.
Old Apr 5, 2005 | 05:57 PM
Just as an additional note, spot filling should be done with a glazing putty, not body filler. The Blue Acryl by 3M is a good choice as it does not require any type of activator.
Old Apr 5, 2005 | 09:17 PM
maxgtr2000's Avatar
KH3 by popular demand
How many layers depends on the thickness of the mat and resin, as long as it is 1/4" or more you are good. 1/4" mat w/ resin is equivient to 3/4 mdf. They sure do make it look easy on them how to videos though.
Old Apr 6, 2005 | 06:08 AM
The original VQ...
I did a couple of layers again , do i need body filer on the shell/outer part to? because this part is going to be in the corner and no one will see it?
the fiberglassing isnt to bad now that i got the hang of it, but damm it stannk!!!
ill get some pics up, but right now the thing just lookslike a buger
Old Apr 6, 2005 | 06:25 AM
The original VQ...
Old Apr 6, 2005 | 06:32 AM
meanbean's Avatar
Body filler is used on the outside of the box in order to get a smooth look/finish. It's also easier to sand than fiberglass. Because of this, it is recommended to fiberglass from the inside of the box rather than the outside but that is sometimes not possible. Since this area will be covered up by the corner, you do not need to use body filler here. However, if you are **** like me and feel that everything has to be perfect regardless of whether or not anyone can see it then go ahead with the body filler. As with everthing, have fun and post those pics when you get the time.
Old Apr 6, 2005 | 11:17 AM
Black Maxima
Should of used epoxy resin. I hate polyester resin.
Old Apr 6, 2005 | 12:55 PM
From the looks of it, you will now need to mount the speaker baffle and wrap the enclosure in polar fleece...then follow the steps I detailed.
Old Apr 6, 2005 | 08:45 PM
The original VQ...
ya i dont have tomuch free time so i can only do alittle bit per day, plus i wanna do it right, i just wanted to make sure i had everything ok before i went on to the next step. hopefully its all done by the end of the month....
Old Apr 7, 2005 | 11:43 PM
max96mike's Avatar
meanbean, where did you get the red gauges?
Old Apr 7, 2005 | 11:45 PM
max96mike's Avatar
METAL MAXIMA...... im new to the forums so i cant access the link that you gave for people interested in a summer NJ/PA/DE Max meet. send me some info.....mth212@aol.com
Old Apr 21, 2005 | 07:26 AM
The original VQ...
*****UPDATE******
Ok, had some time to work on the box yesterday. Got the fleece over it with 1 layer of fiberglas mat all aorund.
reminder this is a mold that will go in the rear left corner of the trunk, right behind the taillight .
Old Apr 21, 2005 | 06:31 PM
Trevmister1610's Avatar
i just got my fiberglass molding all done accept for the sanding and painting, what type of paint should i use?
