Speaker Problem!
Old Apr 8, 2005 | 04:44 PM
MystA RavE's Avatar
Speaker Problem!
I had stock speakers on my GXE. I installed sony xplod 220 watt speakers in the front and left the back ones stock last week. This setup sounded normal. Today I put in the rear sony xplod speakers (same as front) and now I have all 4 of the same speakers. The problem is that they sound like sh*t. There is very limited bass on them and I dont have a subwoofer. My stock rear speakers had about 10 times more bass than the ones I put in today. Is there a problem with something here? Should it sound this way? Will getting an alpine 9847 headunit solve this problem? (dont recommend subwoofers because I want to get this setup working normal without the sub for now)
Old Apr 8, 2005 | 05:03 PM
AscendantMax's Avatar
check the wiring to the speakers and make sure they're correct (plus to plus, minus to minus). if you wire some speakers out of phase, a cancelation effect will happen, and bass response will be crap.
Old Apr 8, 2005 | 05:20 PM
MystA RavE's Avatar
Will it still work if its wired the wrong way? I think I did it right...any other possibilities?
Old Apr 8, 2005 | 06:34 PM
jif718's Avatar
if one of the speakers has the polarity reversed, does that make the rest of the system sound like @#$*?
Old Apr 8, 2005 | 09:46 PM
yes, it can. swap it back to correct the problem.
Old Apr 9, 2005 | 05:27 AM
LeX's Avatar
LeX
Nissan by Nature
another problem is powering aftermarket (especially sony) speakers off the headunit. You really should look into an amped setup with high quality components if you really don't want to install a subwoofer
Old Apr 11, 2005 | 11:50 AM
jakedubb's Avatar
I was wondering the same thing, I've heard that aftermarket speakers on a stock headunit are kind of a bad combination since usually stock headunits provide less power, the speakers are just more efficient. The back left speaker on my 92 max is out and i want to replace it without touching the head unit. So any suggestions?
Old Apr 11, 2005 | 01:05 PM
djfrestyl's Avatar
Suspension Yoda
get a factory speaker - it will sound as good as your other 3
or, replace the rear pair. it will sound clearer but still wont be powered enough
Mar 12, 2020 12:06 AM
Excalibur23
Oct 13, 2015 04:33 PM
popdedop
Sep 11, 2015 11:17 AM
videomano
Sep 8, 2015 03:28 PM
