Good grounding location
Old Apr 9, 2005 | 02:03 PM
MadMax315's Avatar
What is a good grounding location in the trunk for an amp? Its a 4th gen, 95.
Old Apr 9, 2005 | 03:04 PM
Trevmister1610's Avatar
any where on the metal in the trunk. pull up the carpet and find a spot, make sure to look under the and make sure there is nothin there tho
Old Apr 9, 2005 | 03:49 PM
AscendantMax's Avatar
also remember to sand any paint to bare metal to insure a good ground. this will reduce the odds of getting noise into the system.
Old Apr 9, 2005 | 04:06 PM
MadMax315's Avatar
Are there any bolts in the trunk that can be used or do i have to drill a hole?
Old Apr 9, 2005 | 04:09 PM
sunten1
there are bolts you can use...theres one near the seatbelt that i hear is good...another will be the strut(but i hear that there road noise from some people and others say its fine) and there the sparetire well which is what most poeple use
95Maxi
Aug 29, 2015 09:38 PM
