problems with my se-r
Old Apr 13, 2005 | 07:58 PM
Laly's Avatar
i know this is for my sentra, but i figure you maxima guys can help me out. couldnt get much answers on sr20forums. http://sr20forum.com/showthread.php?t=104544
there is the link. basically the questions is, can my system fry my alternator. after i replaced my alternator, the car was running fine and volts were up. as soon as i put my face on, volts dropped dramatically even with no volume. then the alternator would not charge anymore. the wierd thing is, i was running this system for about a half a year like this with no problem. if it is possible for a system to fry an alternator, i will just replace it and drive with no stereo. my car is too fast to be sitting in the garage. id much rather listen to the engine than the stereo anyways. thanks
joshua
Old Apr 13, 2005 | 08:10 PM
2 Da Max's Avatar
hhhm you check all your grounds? especially the big 3?
Old Apr 14, 2005 | 04:35 AM
Laly's Avatar
thats is what it sounded like to me. i cleaned and sanded down the ground on the alternator (grounds to the alternator casing) and another ground that is on the same harness (grounds to the body) when you say th big 3, whick other one are you tlking about? my battery is grounded very well and secure. thanks for the reply.
joshua
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
