Anyone with directions on how to put an overhead screen in a 4th Gen?
Old Apr 17, 2005 | 02:36 PM
sterlingmissile (the .org scammer)
Would appreciate it. Need to routw wires throgh pillar but do not want to do so until I know how to take them off. Any help on mounting ets would also be helpful. Thanks guys.
Old Apr 18, 2005 | 10:30 AM
Anyone who can assist?
Old Apr 20, 2005 | 01:05 PM
I am sure someone has donetthis here? Help pleaseeeeee! Thanks.
Old Apr 23, 2005 | 04:22 PM
No one has done this to their car?
Old May 2, 2005 | 07:38 PM
Anyone - PLEAAASSSSSEEE
Old May 3, 2005 | 01:14 PM
Black Maxima
Pillars are held in by little metal clips. Just pry the pillar off little by little and be gentle.
Old May 3, 2005 | 03:59 PM
D-Bo's Avatar
Droppin logs
I did an overhead install in a friend's mazda. First take out the pillars and the headliner. We used light gauge steel strips and attached them to the framing beneath the roof (be careful where you are screwing/drilling) and then attached the monitor to those strips. You'll have to use the manufacturer's info as to how large a hole to cut in the headliner, the one we had to do was quite large. As far as wiring goes we ran some of it down the front pillars and some of it down the side pillars where the seat belts are. If yours was anything like this one there will be a ton of wiring to run (zip ties are your friend). Once finished though it was solid as a rock, looked like it was stock and worked great. Good luck and what ever you do be patient. Rushing it will only screw it up.
Old May 19, 2005 | 08:07 AM
anyone with specific details for a Maxima?
Finkle
Sep 27, 2015 09:53 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
MaxStock
Aug 12, 2015 08:33 AM
sc10692
Aug 9, 2015 09:37 AM
MikesChevelle
Aug 6, 2015 11:36 AM
