subs not working-help
Old Apr 17, 2005 | 07:20 PM
ruffrida24444
hey guys i noticed my subs would stop working once in a while but it wouldnt cut out in the middle of the song they either worked from the beginning or not at all. yesterday i realized they completely stopped working. i checked every fuse and wire since the box slid back but everything was fine. my Cap and Amp still light up but i have no clue what it may be caused by. maybe somethign going to the head unit? please help me out
thanks
Old Apr 17, 2005 | 07:27 PM
1996blackmax's Avatar
If all the wiring checks out in the trunk, check the wires on the inside of the box. Also check the RCA's on the HU side. I had an intermittent problem with sound cutting out, and a loose RCA turned out to be the culprit. I hope that it is an easy fix.
Old Apr 17, 2005 | 08:30 PM
AscendantMax's Avatar
check all above what 1996blackmax mentioned. sounds like something loose is making sporadic connectivity.
Old Apr 18, 2005 | 08:13 AM
kcidmil's Avatar
I'm not sure how your remote is wired, but that's the problem I had with mine. Of course I have a switch to kill the amp. My system was putting out so much bass it rattled the connectors loose on the switch.
Old Apr 18, 2005 | 12:06 PM
tchockey11's Avatar
Hey 96blackmax, my rca cables are loose too. How much was yours to fix?
Old Apr 18, 2005 | 12:08 PM
2 Da Max's Avatar
if your are rca wires are bad you buy new ones.
Old Apr 18, 2005 | 04:01 PM
2 Da Max is right.
The last time the connection was loose, it was due to the connection having too much tension.
I do not recommend this, but I remember I had some RCA's that were loose on one of my first systems and I just kind of crushed the ends just enough to make them tight. This was pretty ghetto though, but it worked. Back in those high school era days I wanted to use the money for gas instead .
Old Apr 18, 2005 | 07:17 PM
ruffrida24444
i checked all the cables and nothing, even to the headunit today. i had my system installed in sept so i cant imagine $hit broke that fast. i mean everythign lights up (AMP and CAP) every wire is connected and all fuses are fine. i'm just gonna have to stop by the audio place and have em check it out
Old Apr 18, 2005 | 07:32 PM
merovi's Avatar
check everything on the amp. For some reason after moving my amp around it stopped working. So i started playing with all the adjustments and some phase control switch that i've never touched was how i got it to work. I moved it over and then back to where it was before and out of nowhere bass came back. hope that helps.
Old Apr 19, 2005 | 07:48 AM
ruffrida24444
i will try yet again. thanks merovi
Old Apr 22, 2005 | 07:19 AM
ruffrida24444
so i went yesterday and my amp is shot....... only had system for 7 months and my frigg'n amp took a $hit. its still under warranty so thats good. i had a hifonics 1500d watt brutus. with 2 12in pioneers at 350 watts rms. any input?
Old Apr 22, 2005 | 08:11 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Originally Posted by ruffrida24444
any input?
Not to your h/u anymore!!!!!
(sorry, couldn't resist)
Old Apr 22, 2005 | 09:54 AM
kcidmil's Avatar
Sounds like a bad install to me... that's why I only do my own. Where did you get this done btw?
As for an amp going out like that... underpowering Bad ground, too much vibration, gain adjustments too high. There's quite a few things can go wrong. What size wiring did they put in?
Old Apr 22, 2005 | 09:50 PM
ruffrida24444
had it done by my friends older brother who installs car audio $hit in a shop for a living. i'm running 0 gauge from the battery to the back which then gets broken down to smaller gauge. i'm not an expert with this stuff so i mean wut do u mean by a high gain adjustment ? u think that amp iisnt powerful enough for those subs? as for the box heres a pic. http://www.cardomain.com/member_page...508_3_full.jpg
Old Apr 23, 2005 | 08:14 AM
kcidmil's Avatar
Nice clean install, shouldn't been anything wrong with it, so it's probably a bad amp.
As for the gain, there's a little **** that you can turn, to up the power the amp sends the subs. If adjusted too high, it could blow the subs... or over work the amp. Causing premature failure.
Is there rubber washers on the bottom of the amp where it mounts? This helps with vibration, really important when the amp is that close to the subs, and mounted on the box.
I used to install for a living before I joined. And believe me, you can make mistakes even after years of doing it. I'm currently at 7 years of installing stereos... 5 doing setups on subs for SQ or SPL competitions. And I've messed up a couple of times... luckily before the customer ever got their vehicle back. Last 4 years I've been lucky, of course I only do it on the side now.
Old Apr 23, 2005 | 09:31 AM
ruffrida24444
i'm pretty sure i dont have rubber washers at the bottom of the L brackets but i got some in the garage i could unscrew and throw in there. thats pretty hot u been in the business for this long but i guess now its just a hobby. as for the gain screw how do i know how much juice to give the subs? my amp its still under a one yr warr. so i just have to send it back. i just dont want to have this problem again. thanks kcidmil for everything
Old Apr 23, 2005 | 10:54 AM
kcidmil's Avatar
Usually you adjust till it the subs sound right where you want them... but the Max... I repeat THE MAX.. is around halfway. The best way to do it is to turn the gain all the way down, and slowly turn it up till you get your subs right where you want them.
Yeah, I've been doing this for a long time... (since about 15) but there's people out there who can do it better than I can. There's a guy who hit 158.9 db with a 300 watt amp. Now that's a setup and tuning. I've hit 147.6 with my pure SQ setup before, using a 500 watt Memphis amp. But I don't think I could tune a system that well for a 158.9 out of a 300 watt setup.
Now I just setup systems for a little extra cash... not much, but enough to fill the tank in my Frontier and Maxima.
Yeah, when you get your amp back I would recommend adding those rubber washers.
Old Apr 23, 2005 | 02:20 PM
i adjusted my gains by setting the HU to the volume at which i listen to, then slowly turn the gain up on my amp until i start to hear distortion from my sub, then i turn it back down a little bit.
Old Apr 24, 2005 | 12:54 AM
kcidmil's Avatar
I set mine up similar to that... but I usually leave a lot room to up the power. Of course mine is setup for a truck instead of car. You notice distortion a lot sooner.
Old Apr 24, 2005 | 01:14 AM
slickrick's Avatar
how exactly did you hear distortion with your setup and xbl2? im curious as to how it sounds "distorted" as compared to conventional motor design.
Old Apr 24, 2005 | 12:12 PM
nah, this was for my old tens. i just set it to it starts going 'braap braap' instead of 'boom boom' and eased back on it. i didn't touch the gains on the amp when i bridged it to my brahma...even though i should. don't want one VC to get more power than the other one.
Redfox
Sep 28, 2015 10:41 AM
Taino14
Sep 24, 2015 02:51 PM
ballerchris510
Sep 23, 2015 08:46 PM
Car Addict
Audio/Video/Electronics
Aug 27, 2015 09:01 AM
