which sub should i use Jl audio please help...
i have 2 Jl audio W3v2 subs one is a
10W3v2 D2 and the other is a 10W3v2 D4.
the box i will be using them in is a JL audio Maxima Stealth box.
I don't know much about audio so any help would be appreciated.
If u r only using one i would go with the 10W3v2 D2. That way u can power it with a 1ohm amp. U'll b getting more power for ur money running an amp at 1ohm. Do u have an amp already? If so let us know...it may make a difference if u do.
if that amp is 1 ohm stable then yes, i'd get sub that's dvc 2 ohms. if that amp can't take the load, it'll just overheat and go into protection mode. otherwise, i'd wire the 2 ohm dvc sub into a series yielding a 4 ohm load....which most amps are stable at this level.
what does this mean?
sorry i am clue less. can you recommend a better amp to use. i wanna know which sub would be better so i can sell the other.
Originally Posted by JDogg96
zack, I'm gonna be up at wentworth next monday, I can help you hook it up if you want.
Alpine Iva C800
Panasonic indash DVD player
JL audio speakers Xr650CSi's from and rear and Jl stealth box
Originally Posted by zack342
thanks for the offer man. i am still waiting on my DVD player though. as i am installing new head unit
Alpine Iva C800
Alpine Iva C800
That's gonna be a nice setup. I like those xr's, I want to pick up a set of those by the end of the summer if I make enough money for both those and school. Where did you find the stealth box? I was looking for one for a while, but I couldn't find one so I got a JL 12w3v2 and built a ported box for it instead. That sub and that box will definately give you more than you would expect from one 10.
BrandonCause
Sep 20, 2015 10:20 PM
popdedop
Sep 11, 2015 11:17 AM
