my clock/bose radio doesnt work and i cant find the fuse!
Old Sep 19, 2004 | 05:55 PM
2 Da Max's Avatar
ok i wanted to try my new sony head unit but i needed an adapter for the antennae so i took it out and placed back my stock bose head unit and the clock doesnt work. i couldnt find the fuse on the accessory [unless i read it wrong] and the memory on my bose is messed up. everytime i take the key out and put it back in the radio stations get reset? wat could cause this? Did i mess up the harness or is it the memory wire? the bose was working fine before i took it out
Old Sep 20, 2004 | 05:21 PM
2 Da Max's Avatar
need help plzz
Old Sep 21, 2004 | 07:10 AM
xtantmaxima's Avatar
Check the "Mirrors" fuse. If that fuse blows my head unit dies along with the power mirrors.
Old Sep 21, 2004 | 03:47 PM
2 Da Max's Avatar
alrite cool im going to check rite now
Old Sep 21, 2004 | 05:03 PM
2 Da Max's Avatar
nope thats not it i also checked electrical parts fuse and thats good to, what could it be? could it be the bose fuse? its not the audio fuse because my remote wire is connected to that
Old Sep 21, 2004 | 05:13 PM
DMad8724's Avatar
why dont you just check all the fuses?
Old Sep 21, 2004 | 05:35 PM
ManualMaxima's Avatar
5th Gen till she dies!
i knw which one it is........there is a fuse in the very top passenger corner i think it is.....on the panel that says what the fuses are called.....it is the elec parts.....it does not look like it would be a fuse cause it is kinda seperated form the other ones.....it is a 7.5. it happened to me once to. Is your antenna not going up?
Old Sep 21, 2004 | 05:55 PM
2 Da Max's Avatar
uhm i dont think so, actually your rite it hasnt been going up, plus its jammed lol so it should be by the accessory under the steering wheel ?
Old Sep 21, 2004 | 06:22 PM
yea it is under the wheel.....it is at the very very top....i think it is above all the others i might be worng. i know the antenna and the clock are on that fuse....is your homelink working? if not....that is your culpret. that happened to mewhen i replaced my head unit as well......it took me awhile to figure out cause i did not relize there was a fuse there. i took every fuse i could out of that car and checked it and they were all fine......exept that one.
Old Sep 21, 2004 | 07:41 PM
2 Da Max's Avatar
not to sound stupid but what is a homelink?
Old Sep 21, 2004 | 08:36 PM
I think we've had some 4th gen vs. 5th gen confusion.
Homelink is an option for a universal remote in the car. It allows you to consolidate multiple remotes into one convienent sun visor location.
Old Sep 22, 2004 | 11:55 AM
2 Da Max's Avatar
once again thanks guys you have solved my problems, manual maxima u were right about that lonesome 7.5 amp fuse at the top lol. neways i got it fixed and my antennae and clock works. not to mention the radio on the bose doesnt get resedt any more, thats kind of weird how the clock antennae and radio are all on one fuse, anyways thanks
Old Sep 22, 2004 | 11:36 PM
good you solved it....i know it is wierd...been there done that...hahaha
Old Apr 19, 2005 | 07:01 PM
tcrandal's Avatar
Ugh, similar problem, no fix.
I know this is a bit dated, however I'm having a similar problem and I've pulled each fuse and checked them, but they're fine and the BOSE HU won't power on.
A bit more info:
It stopped working while I was installing an audiolink and harness. The 12V and grd shorted out (I know, Im an idiot), and it wouldn't power on after that. Is there any other location that might have a fuse to check? I even checked the top right 7.5 fuse and audio/bose fuses twice based on this thread.
Any help would be greatly appreciated!
Thanks in advance,
Tom
Old Apr 19, 2005 | 07:13 PM
kpr10is's Avatar
Did you test the fuses or just look at them...ive seen fuses that look fine but are busted. Its got to be a fuse somewhere if all you did is ground out the constant power wire.
Old Apr 19, 2005 | 07:16 PM
my99maxisnice's Avatar
Look at this, he makes a thread and no one gives him hell. 2 da max, maybe you are starting to gain a little respect around here...
Old Apr 19, 2005 | 07:23 PM
tcrandal's Avatar
I didn't test them, however I took the spare fuses and used them in the place of the commonly known audio fuses (as marked and as mentioned on this thread). I know someone mentioned on another thread about a fuse under the hood, but I didn't see anything related to audio there.
Old Apr 19, 2005 | 07:31 PM
Trevmister1610's Avatar
is anything else not working other then your hu?
Old Apr 19, 2005 | 07:34 PM
2 Da Max's Avatar
wtf yoo this was soo fawkin long ago when i didnt know shiet about audio who the hell brought this thread back?
Old Apr 19, 2005 | 07:35 PM
2 Da Max's Avatar
look at the fawkin date, its last year and i sounded like a noob
Old Apr 19, 2005 | 07:48 PM
tcrandal's Avatar
Ok, I found it!!!!!!
Desparation caused me to search under the hood, and what I thought previously was the fuse box under the hood, wasn't. I found the fuse area on the right of the battery, and low and behold I saw an audio fuse. Pulled the 15 fuse and wham, it was blown. Replaced it and have my HU back.
Whew. I'm convinced I only figured it out because I posted it on here.
Old Apr 19, 2005 | 11:55 PM
AscendantMax's Avatar
you still do
Old Apr 20, 2005 | 05:01 AM
2 Da Max's Avatar
lol i know my shiet now Gordon!
Old Apr 20, 2005 | 06:56 AM
on a serious note...invest in a circuit test light. they come in handy when you're checking fuses.
jerrod99_se-l
Aug 27, 2015 08:27 PM
Maxinesdaddy
Aug 21, 2015 11:43 PM
jhontelj
Aug 17, 2015 04:07 AM
MikesChevelle
Aug 9, 2015 11:50 AM
kenc15
Aug 5, 2015 08:29 AM
