fuse on power wire 2 the battery
Old May 3, 2005 | 07:34 AM
khynex's Avatar
i read somewhere that they said u should put a fuse on the power wire that u run 2 the battery, does any1 know how 2 do that????
Old May 3, 2005 | 09:57 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Strip the end of the wire running from the amp to the battery, insert it into the fuse hodler and clamp down, then do the same thing to the other end and run it to the (+) of the battery post, attach with ring terminal.
Old May 3, 2005 | 10:16 AM
khynex's Avatar
thanx metal
Old May 3, 2005 | 10:21 AM
Originally Posted by khynex
thanx metal
No prob, man...just make sure you put the fuse somewhere that it may easily be accessed from in the event the fuse goes *pop*
Old May 3, 2005 | 06:01 PM
Chemsol's Avatar
Can't remember why, but I was once told that it is best to fuse as close as possible to the battery. Course maybe cause that's a fairly accessible location...
Old May 3, 2005 | 06:49 PM
maximal's Avatar
yes, fuse within 18" of the battery. i usually do it at about 12". you do this to protect the rest of your car/system from damage/fire. don't forget to disconnect the ground cable from the battery, first. i usually don't put the fuse into the fuseholder until the very end.
Old May 4, 2005 | 11:11 AM
LockNTross's Avatar
haha, could have saved me $20 3 months ago, if I had read and thought about that post. Good advice.
The Frye
Sep 2, 2021 11:03 AM
markevans999
Sep 10, 2015 04:29 PM
Jamie Bowen
Sep 6, 2015 09:59 PM
