The BEST WAY TO REMOVE tough OEM radio screws!
Old Oct 29, 2010 | 04:36 PM
  #41
daze1984's Avatar
I just tried this method and it worked great. didn't hear any "pop" though, i just tightened the screws with a socket wrench intil they would no longer budge, then they came right out. wish i would have come across this thread before i broke a bit using a drill. thanks for posting man.
Old Feb 25, 2011 | 06:11 PM
  #42
paul11273's Avatar
I am ready to try anything. I broke two #2 bits tonight trying to get them out. These are the HARDEST to remove screws I have ever encountered. Ridiculous. What is the point of them being so difficult? Security? That would be dumb.
Old Feb 25, 2011 | 06:13 PM
  #43
paul11273's Avatar
What size are these screws? If I drill them out, what size screw do I need to purchase to replace them?
Thanks.
Old Feb 26, 2011 | 07:30 AM
  #44
djfrestyl's Avatar
Suspension Yoda
Thanks.
Did you read the thread? My method works 100% of the time. Tighten, then loosen.
Replacement screws should come with the head unit you're replacing your Bose with. You should NOT have to drill the screws out.
Old Feb 26, 2011 | 01:55 PM
  #45
Tommiekatt916's Avatar
+1 Its what I do for every any head unit that I need to use factory brackets on... Always tighten first I cant recall it ever NOT working.
Old Feb 26, 2011 | 08:10 PM
  #46
Professor's Avatar
A 10 mm socket works well also, all mine have heads on the for a socket.
Old Feb 27, 2011 | 12:05 PM
  #47
kpr10is's Avatar
Interesting, I'll have to try it. I always go on a low torque setting and allow the 'impact' effect to break it loose.
I've started using my impact driver for these and I've gotten it to work MUCH better than any other method I've tried, which is all of them.
Most of the time I worked at CC I didn't even own an impact driver. Now I couldn't live without one.
Old Mar 8, 2011 | 11:49 AM
  #48
jaxter09's Avatar
i broke to bits when i took mine off
Old Mar 15, 2011 | 05:51 PM
  #49
zach-eminem's Avatar
tried forever to take those off broke a #2 bit then searched on the org and found this thread tightened with a drill and then they came right off thank you
Old Jun 13, 2012 | 07:07 PM
  #50
joshmachine's Avatar
I wish I read this here before i installed my new radio. I could only remove 1 screw cleanly and had to drill out the rest of them. Thanks OP.
-ReLLiK-
Apr 29, 2016 06:25 PM
mikeg75
Nov 30, 2015 05:12 PM
thenewguyy
Sep 12, 2015 11:12 AM
Pnjboyzz
Sep 4, 2015 09:04 AM
