Factory Radio Harness Is Cut Up!! HELP !!!!!!
Old May 16, 2005 | 11:49 AM
KRMaxima21's Avatar
The wires for my radio in my 95 are completely hacked up (no factory harness plug for the radio). Nothing a little soldering or crimp connections cant fix but I just ordered a JVC DVD player and I wanted to know should I just use an aftermarket radio harness and hardwire it in or do I need to wire a factory harness to the cut wires and then plug the aftermarket harness to the factory harness plug and then wire the JVC harness to the aftermarket harness? I know it sounds confusing but I honestly dont know in which direction should I go with this plus I dont want to pay something a nice amount of money for something I can probably do myself.
Old May 16, 2005 | 12:10 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Yes, it does - namely because you have never f-cking heard of the word 'PUNCTUATION'.
If you can do it yourself, then why don't you? I would trace the original harness to the perceeding harness, remove the whole mess, and solderit back together. Another suggestion would be just to cut the lines, strip some new ends and rejoin the two open ends with a short splice of 20GA. Just twist the wires together and tape them...the connection won't be as solid as a solder job would be, however it will work equally as well.
James92SE
142
Jan 2, 2024 09:23 AM
9aj9
Apr 5, 2020 12:11 AM
Pnjboyzz
Sep 4, 2015 09:04 AM
