Is this safe?
Old May 17, 2005 | 09:21 AM
99maxk2's Avatar
Is this safe?
Is it O.K. to run a 4 guage wire from the battery to a capacitor. Then have two 8 guage wires come from the capacitor to each of my amps. Would i need to have a fuse on each line?
Or would i be better off splitter the 4 guage, with a splitter, into two 8 guages.
Reason I am asking is to see if i can save money by not having to by a splitter, and basically using the capacitor i have now as a splitter.
Old May 17, 2005 | 10:10 AM
filtor1's Avatar
What you did will be fine. My first system was wired the same way for three yrs with no issue.
Old May 17, 2005 | 10:20 AM
99maxk2's Avatar
So just having one fuse on the main power wire (4 guage) will be O.K.? I don't need any other fuses on the 8 guages?
Old May 17, 2005 | 10:21 AM
merovi's Avatar
can u really fit 1 4 gauge wire and 2 8 gauge wires into 1 side of your cap?
Old May 17, 2005 | 10:31 AM
99maxk2's Avatar
yes.... very easily. That is why I am asking if it is safe.
Old May 17, 2005 | 11:00 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Yes its fine and safe. One main fuse is all thats needed.
Old May 17, 2005 | 06:39 PM
99maxk2's Avatar
Alright cool. I have a 150 Amp fuse on my 4 guage wire. I have a 1200 watt amp and a 600 watt amp. Does that seem like the right "ampage" fuse to have on that line, or should i do a lesser powered fuse.
Old May 17, 2005 | 07:49 PM
slickrick's Avatar
if anything you need larger wire if in fact those are the rms ratings.
Old May 17, 2005 | 07:50 PM
merovi's Avatar
if u want to know the amperage of the fuse u need in the line just add the number on ur fuses together. if u have 2 25 amp fuses in 1 amp and 1 30 amp fuse in another u need a 80 amp fuse in the line. 25+25+30 = 80
Old May 17, 2005 | 07:57 PM
99maxk2's Avatar
No, those are the peak power wattage
So it might be overkill with that 150A fuse...that could be bad.. right?
Old May 17, 2005 | 07:59 PM
slickrick's Avatar
150 is bad IMO for a real 900 watts rms....try an 80 amp fuse and if you keep blowing those you will see that the amps put out more power than i guessed, or you are clipping and drawing more current from the amps. you have to understand music almost never draws the full power from the amps.
Old May 17, 2005 | 09:27 PM
'96MaxGLE's Avatar
It really wouldn't b a bad thing to have a 150A fuse would it? Isn't it just more than he needs?
Old May 17, 2005 | 09:29 PM
slickrick's Avatar
well if your amps will never pull much more than HALF that current then it is a bad thing because it almost serves no purpose.
Old May 17, 2005 | 09:40 PM
'96MaxGLE's Avatar
OK that's what i was thinking. How much power RMS r u running with one capacitor, and how many farad is the cap?
Old May 17, 2005 | 10:01 PM
slickrick's Avatar
umn none and none.
Old May 17, 2005 | 10:03 PM
'96MaxGLE's Avatar
LOL....just tryin to get the post back on track...
MaxStock
Dec 5, 2016 05:19 PM
sliptap
Sep 30, 2015 05:57 AM
Andy29
Sep 29, 2015 05:32 AM
bumpypickle
Sep 20, 2015 08:22 AM
