good ground in the trunk
Old May 22, 2005 | 06:11 PM
dayglo's Avatar
hi im using my trunk lock bolt as a ground right now and the wire is short...so its always in the way, even with my messy wirring job. whats a better place to put it back there? also the guage of wire is like 12 or 10 i think, is it alright if i used 8guage speaker wire instead? i dont know what power goes through a ground wire like this one.. when i put it somewhere else, it doesnt work or it sparks
if i can use this speaker wire to do a half assed job then id just use the same ground spot but i can use this roll of wire i have here to put around neatly instead of through the middle of my trunk in the way. anyways thanks
PAAAAAAAAAAAAAYCE
Old May 22, 2005 | 06:14 PM
AscendantMax's Avatar
the ground wire should be as short as possible, and be of the same gauge of the power wire. just find a good solid spot on the chassis and ground it there. be sure to sand off any paint in the area to insure a solid ground.
Old May 22, 2005 | 06:23 PM
kpr10is's Avatar
umm youve got other problems if your using a 12 gauge ground. Dont tell me your running 12 gauge power too. Even the smallest of amps should get 8 gauge power and ground IMO. And +1 to ascendant.
PAAAAAAAAAAAAAAAYCE?? Oh **** I havent installed my ebonics translator yet.
-kevin
(p.s. note the sarcasm, im jfwy)
Old May 22, 2005 | 07:21 PM
Pearl96Max's Avatar
I tend to get a bit irritable
+1 to the above posts.
You have 8awg SPEAKER wire and your using 12awg POWER wire??
Old May 22, 2005 | 07:31 PM
don't think i've ever heard anyone using larger speaker wires than their power wire.
Old May 22, 2005 | 07:34 PM
Pearl96Max's Avatar
Yea it kinda had me confuse a bit there.
I mean I had 8awg to my subs, but 0 to my amps. LoL Hmm Im wondering...8 to my amps and 0 to my subs?
Old May 22, 2005 | 07:42 PM
that's a big **** wire going to your subs. imagine trying bend a 0 gauge around to a dvc sub to wire it into a series
Old May 22, 2005 | 11:13 PM
camn's Avatar
Ive never done it . . but I think you COULD use speaker wire for your ground.. if thats what you are asking.
As far as placement.... you can pop a sheet metal screw through anywhere you like.. Just sand the sit a bit beforehand to clear the paint. And do it somewhere where you arent going to cause a leak. Thats the easy yet good way to do it.
c
Old May 23, 2005 | 11:29 PM
PARALLEX's Avatar
haha guess theres a first for everything... i agree change your wires to 8 guage or less for ground and for power... good luck
Old May 24, 2005 | 12:44 AM
slickrick's Avatar
oy vey i missed this thread...12 gauge is only meant for 2 things: a shotgun or strictly speaker wire.
Old May 24, 2005 | 06:22 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Seriously, you might have 2DaMax beat
Matt93SE
May 24, 2019 02:58 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
TMartinLVNV
Aug 16, 2015 01:48 PM
doobadoo
Aug 15, 2015 06:43 PM
