Viper techs Step in.......
Old May 22, 2005 | 06:17 PM
99 SE-L
Hey guys well iam currently installing a Viper 791 vx alarm in my 2002 maxima my freind and I are almost done the car starts /locks/unlocks shows conformation back to the pager but we have 2 small problems trunk works then dosnet now it stopped even wiht a relay and the door pins worked but now dont any ideas will be appreciated thank you..
Old May 22, 2005 | 06:49 PM
NOCturnalI30's Avatar
Did you use resistors when u hooked up the wires if not you could have fried the brain. check your wireing to see everything is hooked up properly GL
Old May 22, 2005 | 07:02 PM
99 SE-L
Why would Resistors matter.. not enough power ,I dont think so and if the brain would be fried then car would not start or unlock like it is currently doing...
Old May 22, 2005 | 08:05 PM
no because there is power running back to the brain of your alarm thats y i asked did u put in any resistors i had to for my brain
Old May 22, 2005 | 08:28 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Ummm resistors??? Are you referring to DIODES? which are only needed for the door triggers for isolation.
Old May 23, 2005 | 06:42 AM
99 SE-L
Hey don i tried to contect you can u help me wiht my trunk and door pins i have the diodes... thanks
Old May 23, 2005 | 06:50 AM
Pearl96Max's Avatar
Tried calling you back, but no answer.
gigabyte
Jan 6, 2017 06:05 PM
Redfox
Sep 28, 2015 10:41 AM
REDinLV
Sep 28, 2015 12:31 AM
