Component crossover location ?
Old May 22, 2005 | 10:35 PM
7EyesOpen's Avatar
I just got some Polk Components. The mid/Sub fits perfect, but the tweeter or door grill needs modification. Where is the best place to mount the crossovers?
Ok!
Heres another tough question. I also have a 1/0 fuse holder. This thang is huge. Where is the best place to mount this?
Old May 22, 2005 | 10:50 PM
slickrick's Avatar
kick panels work well for xovers.
Old May 23, 2005 | 06:09 AM
7EyesOpen's Avatar
Good idea! Why didn't think about that?
How about the fuse holder? The engine bay is crowded enough already.
Old May 23, 2005 | 08:01 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Crowd it some more. The whole purpose of running a fuse close to the engine is to minimize the distance an excessive voltage spike can travel.
I thought you did not want to run 1/0, though.
What kind of wire did you end up using?
Old May 23, 2005 | 09:19 AM
seventy5impala's Avatar
i ditched my ANL fuse holder after i saw how liited space is on the right side of that car....AGU should be fine....800 watts RMS
Old May 24, 2005 | 04:59 AM
7EyesOpen's Avatar
I went with the Knukonceptz Kompressed 1/0 Gauge because its flat and they claimed it was slightly thicker than their Kolossus 4 Gauge. However, I still find it a bit difficult working it into a 1/0 connection port. Go figure!
Old May 24, 2005 | 05:29 AM
Try twisting the wire tight...there's a lotta wire there!!!! You will be quite pleased with your wire's performance!
Old May 24, 2005 | 05:34 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Mine are in the trunk.
Old May 25, 2005 | 04:37 AM
7EyesOpen's Avatar
Thanks for the ideas. I have a Non-Bose stock component set up in the front doors. Does anyone know if there is a stock crossover in the wire line? Where it's located?
Old May 25, 2005 | 04:58 AM
There are none.
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
