need box plans for one 12" sub
Old 05-26-2005, 07:49 PM
  #41
danhaman's Avatar
Use the cup, if you plan on taking the box out of your car much [for trips or whatever].
dh
danhaman is offline
Old 05-27-2005, 08:23 PM
  #42
roll4life's Avatar
hmm yea i gota find a terminal cup and if i cant ill just make one somehow..but anyways is it okay to ground the amp to the metal part of the seat that is connected to the frame? or is it not direct enough?
roll4life is offline
Old 05-27-2005, 08:51 PM
  #43
AscendantMax's Avatar
i'd connect it to the frame itself.
AscendantMax is offline
Old 05-28-2005, 12:59 PM
  #44
roll4life's Avatar
yea same, but the ring is not big enough and the screw doesnt fit in between the circle...since im mounting my amp under the passengers seat..are there any other grounding points?
Old 05-28-2005, 04:12 PM
  #45
just get a self tapping screw and secure it to another area.
Old 05-28-2005, 06:01 PM
  #46
roll4life's Avatar
aigh gang i got some pics and some questions
heres the box..all done cept carpet
Old 05-28-2005, 06:02 PM
  #47
slickrick's Avatar
what are your questions?
slickrick is offline
  #48
where's the question?
are you gonna carpet it?
Old 05-28-2005, 06:05 PM
  #49
roll4life's Avatar
the box is 1.5 cu ft...anyways my questions are..
i have a question on which diagram i should use? the sub is at 4ohms and the amp will be around 400-500 rms at 4 ohms...im kinda confused on which one is the right one..either example 1 or 2..any help or tips would be awesome
Old 05-28-2005, 07:23 PM
  #50
is the amp stable at 2 ohms? you can only wire that sub into 2 or 8 ohms. you're going to see roughly twice the power at 2 ohms...and about half that at 8 ohms.
Old 05-29-2005, 08:41 AM
  #51
roll4life's Avatar
hmm i see thanks man..i wired it up this morning and i hope it works..otherwise i'll have to take the sub out of the box
Old 05-29-2005, 08:46 AM
  #52
what amp are you using?
Old 05-29-2005, 02:33 PM
  #53
roll4life's Avatar
MRD-M605 alpine v12..its got like 600 rms at 2 ohms..and i just installed it..system sounds pretty damn good..whole car shakes..but i cant get this gain thing straight..i'm not sure how to set it..ill post pics real soon today
Old 05-30-2005, 12:45 PM
  #54
roll4life's Avatar
haha sorry for bothering u guys again..but i got a few more questions..anyways..on the amp theres a **** and it says subsonic filter OFF 15Hz or 30 Hz..which one do i pick? also theres a little **** that says LP filter goes from 30Hz to 200 Hz and last theres a know that says LP slope that says 12dB or 24dB..lol im so confused
Old 05-30-2005, 01:44 PM
  #55
slickrick's Avatar
SSF off because you have a sealed box...however if you want to really prevent the sub from overexcursion put it on. try it at each setting and see how you like it. id set the LPF at 80hz wit ha 24db per octave slope.
Old 05-30-2005, 03:15 PM
  #56
roll4life's Avatar
hmm sounds good man..ill try the settings out and see which ones best..but can over exurcision blow the sub?
Old 05-30-2005, 03:21 PM
  #57
slickrick's Avatar
yep...you blow it mechanically. depending the the design of the sub it happens slightly different to each driver. overall, just remember going past xmax for extended periods of time causes it to blow mechanically. the SSF's main purpose is to prevent overexcursion in a ported box below tuning when the driver unloads. for sealed boxes it is not necessary but I've had people prefer the sound of the SSF being on which is odd but o well.
Old 05-30-2005, 03:32 PM
  #58
wow, slick starting to sound like he knows his stuff
Old 05-31-2005, 03:45 PM
  #59
roll4life's Avatar
hmm i see..i'll leave the filter on then, i love all this bass so far..my mirrors shake like crazy..now all i gota do now is carpet the box somehow..but it seems like there is a lot more bass when listing to cd's rather than the radio..radio u really have to turn it up to hear the bass
Old 05-31-2005, 09:28 PM
  #60
regular radio quality sucks compared to cd. glad you liking the bass
litch
123
01-04-2024 07:01 PM
aw11power
10-10-2021 04:57 AM
MaxiNoob98
10-02-2015 10:13 PM
Garrettz459
09-28-2015 02:50 PM
09-27-2015 08:37 AM
Quick Reply: need box plans for one 12" sub
