2nd amp wiring help
Old May 26, 2005 | 07:42 AM
biggun's Avatar
2nd amp wiring help
I have a kicker 350.2 2ch amp powering my 2 10' kicker cvrs, i replaced all my door speakers and bought a new amp for the 4 speakers, do i have to run a new power cable from the battery and a new remote turn on power cable to the new amp, or can i just splice into the power cable and remote cable from my already installed kicker amp to the 500watt 4ch amp? Iam gonna mount it beside the kicker amp.
Old May 26, 2005 | 08:37 AM
maxgtr2000's Avatar
KH3 by popular demand
If you ran 4 ga. as a power wire you could just get a distribution block and wire the new amp in, if you are running 8 ga or less, I would just rerun 4ga with a distrib. block as stated before. You can tap into the remote with no problems, the remote will be good as long as you are not running like more than 4 items, more than that you should run a relay. If you get MTX amps you don't need a remote.
Old May 26, 2005 | 03:51 PM
my99maxisnice's Avatar
yea, buy a distro block (wal mart has a fused one for like 10 bucks). I agree with maxgtr, upgrade your wiring to 4 guage, and make sure to buy a big inline fuse, not sure on the amperage, but I kept blowing my fuse that was sufficient enough for one amp.
Old May 26, 2005 | 07:42 PM
danhaman's Avatar
I thought the12volt.com had a good write-up about how important it is to use the correct size wire, and about fusing, but I can't find it. Long story short, use a fused distrobution block and wire size sufficient for the amperage draw from both amps [fused at the battery & at the distro block].
dh
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
