Non-Bose System in 5th Gen ?
Old May 26, 2005 | 07:06 PM
terp03se's Avatar
Traded my 92 max in for an 03 with the non-bose HU. I pulled the stereo out of my old ride(aftermarket HU, kappa 5 1/4" components, kappa 6x9's and 2 amps) and want to install in the 03.
Question is two parts 1) Can do this with the existing stock HU? and 2) If I can, does it make sense?
Old May 26, 2005 | 07:13 PM
danhaman's Avatar
You want to install the aftermarket HU, and keep the stock HU operational? Any particular reason?
dh
Old May 26, 2005 | 07:17 PM
terp03se's Avatar
Sorry for the confusion, don't think I worded the first post well.
2 options:
1) Install speakers/amps with stock HU
2) Install speakers/amps/aftermarket HU and remove stock HU
Is option 1 possible? If so, does it make sense?
Old May 26, 2005 | 07:47 PM
danhaman's Avatar
Sure, all you need is a line output converter [unless the amp has speaker level inputs, then using those may be okay]. Some people don't think you can get as good of sound from them, but I've never had a bad sounding stereo using them, just make sure you use a good one.
dh
Old May 26, 2005 | 08:16 PM
terp03se's Avatar
Thanks for the input above.
Will the sound quality be that much different between the aftermarket and stock HU?
Old May 26, 2005 | 08:42 PM
kpr10is's Avatar
Option 1 makes NO SENSE AT ALL. There will be WORLDS of difference between powering amps with a line output converter and an aftermarket deck. I install at Circuit City, and not to be contradictory or start an argument, but out of the multiple stereos I install every day, I have never had a single amp sound what i would consider good with high level input. A line output converter is a little better, but the only time I would ever run one is when adding a sub to a complete factory system. When adding a 4 channel amp, or speakers, or anything else at all, you DEFINITELY need an aftermarket head unit. When starting a system from scratch, the radio and 4 speakers should be the first things you replace, then worry about amps and subs. Your system is only as good as its weakest link, and factory head units, whether they are Bose or not, SUCK.
On a side note, youll need to make or buy 6.5 to 5.25 adapters to get your 5.25 speakers to fit in front, and since you don't have Bose, youll either need to cut a hole in the door or A-pillar to make a spot for the tweeter. Or you can buy the factory A-pillars with the grill on them, and make everything look factory. Youll also have to cut the rear door to hell to get a 6x9 to fit in there. Your better off buying a decent set of 6.5" coaxials for the rear, and selling the 6x9s you currently have.
-Kevin
Old May 26, 2005 | 09:06 PM
danhaman's Avatar
I pretty much agree with you about high level inputs on amps, but it would be something he could check out for himself, so see if it's worth saving the $30ish for a decent LOC.
I almost completely disgree with the needing of an aftermarket head unit for 'good' sound. If the stock headunit has a lot of EQ'ing [vs the flat response you'll get from an aftermarket hu], then you have a good point [and yes, many stock stereos nowadays do], but if the signal is flat [ala bose headunits prior to the amp], then it's not necessarily the case.
There's a new product coming out [may be out] by JL that flattens the signal, and adds an aux input, that would be great for keeping OEM headunits w/ nav [or climate controls, etc. . .]. Not really a player in this discussion as it costs like $300-400, but worth mentioning.
dh
Old May 27, 2005 | 01:30 AM
slickrick's Avatar
dh
but its a NON bose radio.
Old May 27, 2005 | 05:27 AM
terp03se's Avatar
-Kevin
Ok, makes sense now, option 2 it is. Given I have an aftermarket HU anyways, cost is negligible. Personally, I just like the clean look of the stock stereo vs. the small aftermarket with gaping slot underneath the HU after install.
Fortunatley my A-pillar has the tweeter opening, so I'm set there. Regarding the 6x9's, I was afraid of that. I was going to the pull the door and see how bad it looked before I made a decision. Probably go with the 6.5" to keep everything clean.
Ever seen the 6x9"s mounted in the rear deck on this model?
Old May 27, 2005 | 06:18 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
No, because 6x9s are teh suck. Music was intended to be repoduced through a conical geometry, not footballs. Do yourself a favor, ditch the footballs, and talk to Don about some nice rear coaxes.
Old May 27, 2005 | 07:30 AM
terp03se's Avatar
who knew I would need to pull out my physics books for this discussion....
Old May 27, 2005 | 10:03 AM
slickrick's Avatar
6x9=crap. get a double din radio or an indash tv to solve the pocket problem in the dash.
Old May 27, 2005 | 10:19 AM
kpr10is's Avatar
dh
1)This is what were here for, so he doesnt have to find stuff out himself, we can tell him whats good
2)I dont know what kind of head unit you have, but mine has a 7 band EQ. Name a factory radio that has that Not to mention my 16 volt preouts own you and Bose. Its not completely impossible to get good sound off a factory deck, but it takes a whole lot of work and knowing what your doing. Which most people dont have the money or knowledge for. (i.e. line driver, etc)
Old May 27, 2005 | 02:44 PM
danhaman's Avatar
slick - I know he doesn't have a bose, I simply meant, like a bose system, some stock headunits don't mess with the signal [I don't know if the non-bose does or not].
kpr - I am definitely not saying that aftermarket head units don't have thier place, they do, as do stock head units. Aftermarket headunits are much better for specific applications, if the user wants [eq, dvd, higher line voltages, dvd, navigation, satellite radio, . . .]. Stock headunits will almost always have better regular radio reception, and will almost always look better [I don't mean aftermarket stereos look bad, just that it often takes a very good amount of fabrication to make it look 'at home' in the dash], plus the stock unit is already integrated with climate controls, navigation, and/or steering wheel controls, which aftermarket head units are not compatible with [yes a good installer can make some of above work with aftermarket, but not all, and not cheaply usually].
As for 16 volt pre-outs - man that's a little overkill. Besides, if you don't have noise in your system, then it makes no difference whatsoever. High voltage outputs simply allow you to raise the noise floor. A good LOC can provide plenty of voltage to keep the noise floor as low as anyone would ever need.
In this particular case, it sounds like terp doesn't have much need to keep the stock headunit [except looks, which can be huge for some people], and perhaps going with his already owned aftermarket headunit is the best solution. I just don't like comments like 'stock headunits suck', etc. . .
dh
Old May 27, 2005 | 03:15 PM
kpr10is's Avatar
We were talking about SQ...If I had factory integrated Nav and Sat Radio I would probably end up keeping that also. But IMO for the majority of people out there, including on this board, unless it has those theres no reason to keep a factory deck. To each his own.
Its 16 volts to run balanced with Eclipse's Balanced Line Adapter.
-kevin
Old May 27, 2005 | 03:18 PM
slickrick's Avatar
i will agree with much better radio reception with the stock unit...however with my TV I've never used the radio once.
Old May 28, 2005 | 09:40 AM
danhaman's Avatar
-kevin
Absolutely, if you are running balanced lines, you'd need an aftermarket headunit that's compatible.
I dig the look of the integrated factory head unit, and as long as it has the capabilities you want, I'm a fan of sticking with it.
dh
MikesChevelle
Nov 23, 2024 11:17 AM
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
wyobbagy
Aug 15, 2015 02:28 PM
